tops911's Avatar
clutch pedal
Hi,
I have an '82 930 and have a question ref the clutch pedal. I've replaced the cable and adjusted the clutch. While putting in the new cable I saw that the return spring in the pedal box was missing. I got a replacement spring and put it on; however, now the pedal stops before it returns completely (about an inch or so from the top). The "Omega" spring is still good. I can hook my toe under the pedal and pull it up all the way. Has anyone run into this? Should I just adjust the clutch with the pedal at this lower location? I think I had the same issue with the SC I used to own.
Thanks Frank
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 04-09-2011, 02:21 PM
tops911's Avatar
I got it working better; however, I think I need a new "omega" spring. After crawling around underneath the car the spring does not pull the clutch arm back the last little bit.
Old 04-10-2011, 06:23 PM
Smart quod bastardus
fredmeister's Avatar
I have the same symptoms and both my springs are in good shape. Had it on my 911SC also and never worried about it. As long as your clutch engages and releases fully and you have enough free play adjusted your fine. I think as the pedal nears full return that last inch you describe the mechanical leverage in the pedal arm geometry in the pedal box is not enuff to return it to its stop. Its almost as if the pedal goes overcenter slightly inside the pedal box if you watch the motion of the return spring in there.
Hard to explain but ithe short answer is i would not worry about it.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 04-12-2011, 12:17 PM
