-   -   new turbo......problem! (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/603240-new-turbo-problem.html)
minirally 04-16-2011 10:06 AM
hi guys, here my problem if someone want to help me!
i just put a new k27 turbo........when i start de car,it began to smoke a little, no worry, i think its the old oil in the muffler burning....but after 4 to 5 minutes, so much smoke, i lost all the around house!!! amazing how much smoke!!!
someone have an idea?
thanks,
andré
slyguy 04-16-2011 12:29 PM
Is the turbo brand new or rebuilt? KKK? Did you prime the turbo and run oil through the feed line before starting the engine? Was there anything wrong with the old turbo? Ive had the smoking like st helens turbo on a couple of occasions and each time it was seal gone bad, one K27HF due to coked oil particles in my system and one K27 due to heat. Both required rebuild.
mark houghton 04-16-2011 03:58 PM
Originally Posted by slyguy (Post 5967357)
Ive had the smoking like st helens turbo on a couple of occasions....
Been there; I mean, when St Helens blew her top. I was about a hundred miles downwind....not a pretty sight for several days. Sorry, off topic....
A new turbo should not exhibit the characteristics described. Definitely would indicate bad seals. Or, perhaps, did someone mess with the check-ball restrictor in the feed line?
minirally 04-17-2011 03:20 PM
the problem is from last year on the race track!! blow lot of smoke...so much,they stop the session!! open the turbo at the shop,result,blow turbo, now a new-rebuild one....and still the same problem????
can the check ball broken? any idea....i,m confuse about that.
Sam Matthews 04-17-2011 06:36 PM
look at post turbo blow out hope this helps
minirally 04-19-2011 02:07 AM
thanks for the tread,i,ll check all that!
minirally 04-21-2011 04:46 PM
finally, it is the shaft from the pump broken! thanks all.
minirally 04-21-2011 05:26 PM
anyone has a scavenging pupm for sell..or where to buy one? thanks
JFairman 04-21-2011 07:10 PM
What part of the shaft broke?
You can fix it if the steel pin that is 90* to the camshaft and driven by the 2 allen heads that hold the air pump pulley onto the end of the camshaft wore out and broke.
That steel pin runs dry where it is driven by the top of the allen head bolts and eventually wears through and breaks. The tops of the allen heads get worn down too and a little 60% moly paste or molybdenum grease would help there.
When I replaced my cams, rocker arms and shafts a few years ago I noticed mine is worn almost halfway through after 125,000 miles.
I'll have to address that soon before it wears out and breaks off.
Cole recently noticed his is worn too and I think he posted a way or suggestion to replace that pin.
Moly paste is a good lubricant for something like this since it is 60% molybdenum disufide which adheres to ferrous metale like steel and iron and won't fling off.
Moly grease only has around 5-7% molybdenum disulfide in it.
http://forums.pelicanparts.com/uploa...1303437774.jpg
minirally 04-25-2011 05:33 PM
i remove the broken pin...and put a new one! happy,the seal of the turbo is ok!
love this forum,and the people here!
