Happiest when Tinkering
gsmith660's Avatar
keyword lookup "linkage" should do it. I modified my 2.7 linkage to fit the 3.2 intake works fine.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 05-09-2011, 06:18 PM
Do you know what the thread size was, 1/4"?
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!----
-1978 911 SC TURBO, Minerva Blue Targa 965 update.
-2008 550i M-Sport
Old 05-09-2011, 06:22 PM
gsmith660's Avatar
I think it is metric you can buy the rod and cut to length and thread the ends to fit the stock ball connectors not sure what size they are.
Old 05-09-2011, 06:28 PM
Problem Solved:
Just added a little length to the linkage from the transmission to the plate. I purchased a M5 rod, cut to length and attached with a M5 coupler nut. Pretty simple.
A 10/32 rod seemed to work as well, but went with metric.
Jeremy C.
-2008 550i M-Sport
Old 05-10-2011, 03:12 PM
OK Some More Updates
"Freeze Plug" removed exposing the SC Cam.
Jeremy C.
-2008 550i M-Sport
Old 05-15-2011, 03:52 PM
Dowels inserted to drive the scavenge pump.
Jeremy C.
-2008 550i M-Sport
Old 05-15-2011, 03:54 PM
Scavenge pump mounted.
Jeremy C.
-2008 550i M-Sport
Old 05-15-2011, 03:55 PM
M&K Y Pipe mounted to the 993 HEs.
Of course a gratuitous pic of the welding.
Jeremy C.
-2008 550i M-Sport
Old 05-15-2011, 03:58 PM
K27, Drip- tank, and 930 Down pipe mounted.
Jeremy C.
-2008 550i M-Sport
Old 05-15-2011, 03:59 PM
Jeremy C.
-2008 550i M-Sport
Old 05-15-2011, 04:00 PM
jsveb's Avatar
Looks really good.
I bet it is a lot of fun, putting all the pieces together now.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 05-15-2011, 04:37 PM
laughac's Avatar
Send a message via AIM to laughac
Sweet!
Old 05-15-2011, 09:31 PM
proffighter's Avatar
Where do you plan to mount the BOV? It looks like you don't have the 965 elbow. It's cheap (OEM-93011038200 41.75USD from our host) and probably one of the best solutions for BOV location:
Roland
930 Turbo '81 Too many modifications to list
Old 05-15-2011, 11:30 PM
Thanks Guys!
Roland there is a port welded on the back of the Intercooler for a TurboXS BOV. I have not decided if I will use it or not as it is getting tight on that side.
I do already have the as I bought one a while back in anticipation that I would get a larger intercooler... now I have one, but because of this extra port may not need the elbow.
Jeremy C.
-2008 550i M-Sport
Old 05-16-2011, 03:11 AM
I am getting to the point where I have questions. Specifically vacuum or boost port hoses and where to put them.
1) Where does the BOV get its signal from, looks like off the IC?
2) Where do the WGs get their signal from?
2 a.) Since I dual WGs. Do each need thier own signal or can I "T" one signal and split it to the two WGs?
3) Where do I attach the line from the pod on the distributor?
Thanks!
Jeremy C.
-2008 550i M-Sport
Old 05-16-2011, 03:14 AM
Maybe this helps:
T-piece will be fine for BOVs
Roland
Old 05-16-2011, 05:34 AM
And here the Euro version out of manual:
Roland
Old 05-16-2011, 05:38 AM
Thanks, that should help, but I am sure I still ill have a question or two.
Boost would be above the throttle plate and vacuum below it, correct?
Jeremy C.
-2008 550i M-Sport
Old 05-16-2011, 05:50 AM
sjf911's Avatar
Correct. Also, like the diagrams above, you really should take the pressure signal for the waste gate off before the intercooler.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 05-16-2011, 05:56 AM
And you mean WGs, not BOVs?
I will shoot you a pic of the ports I have on the IC.
I am not sure sure I have a port to go to the AAV. Actually I am pretty sure I do not as I remember installing a small K&N filter on it.
Jeremy C.
-2008 550i M-Sport
