-   -   Please help recognizing intercooler (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/606254-please-help-recognizing-intercooler.html)
ornas 05-02-2011 03:12 PM
Hi, I was offered this intercooler. Could you tell me what "brand" it may be and what it could be worth?http://forums.pelicanparts.com/uploa...1304374321.jpg
jcc911 05-02-2011 04:20 PM
I believe it is B&B. I would say 600-900 USD
David 05-02-2011 05:44 PM
I thought B&B's were polished. Either way it looks like it's probably from the same mold and that price sounds right.
mark houghton 05-02-2011 06:02 PM
Looks like mine. The castings (both end pieces) are not polished (I ground mine down with elbow grease and got somewhat of a shean on them). The front and rear plate surfaces are somewhat polished, though.
A good unit in my opinion, but then I'm biased.
jonesb930 05-02-2011 06:25 PM
Are there issues with the shroud with these? It looks very thick.
Bill
Kraftday 05-02-2011 06:27 PM
Thats a B&B IC for sure. Current MSRP is $2006 new for that kit. Usually take about a month to order new. Great unit, direct replacement, good flow and effective. Also made in Arizona, USA! They come in plain sand casting from factory. This is a non-long neck unit meaning it uses the original equipment boost control valve. Half of new would be decent deal. Cheers
mark houghton 05-02-2011 07:06 PM
I would have to go back and look, but I think I bought mine used about 5 years ago for about $750. And you're right about the sand casting. It can be ground down, smoothed out and polished with a lot of work. Or I suppose a person could paint it, but I like the raw metal finish with occasional metal polish wax.
I have yet to install a sealing gasket to mate up with the lid, as the IC sits real real close to the grill. There is no grove machined into the IC to accept a rubber lip, so a person would have to be creative on how to attach a seal.
RarlyL8 05-02-2011 07:29 PM
Here is a black one that has been in use off and on for 15 years. Decent unit for the money. Short neck, doesn't fit stock lid shroud. ~$800 used is the going rate.
http://forums.pelicanparts.com/uploa...1304389768.jpg
OSI930 05-03-2011 08:33 AM
They do shine up pretty good but it is a lot of work at first, especially the end tanks:
http://forums.pelicanparts.com/uploa...1304436680.jpg
jsveb 05-03-2011 08:39 AM
"They do shine up pretty good but it is a lot of work at first, especially the end tanks"
You got too much time... :)
