-   -   Floating rotors (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/608905-floating-rotors.html)
millhaus 05-15-2011 06:48 PM
Floating rotors
If I want to convert my 1980 930 floating rotors to the 1981 and later fixed rotor, does anyone know if the 911 SC hubs will work on the 930 without floating rotors?
I've been researching part numbers on our host and there are different part numbers for a 1981 930 hub vs. a 1981 911SC hub but the description seems to indicate the SC hubs can be used on the 930 without floating rotors.
Can anyone confirm this?
Tom
infraredcalvin 05-15-2011 08:44 PM
Contact Steve at rennsport systems in Portland, Oregon, he'll give you all the info you need, and should have some tips for the install as well.
