Tinkering Pays!!
mooney265's Avatar
Paint Stock Wastegate?
Is it a bad idea to paint the circled portion of the stock wastegate? Mine's pretty rusty [that's not mine in picture...] and would like to freshen it up...
But, don't know what that will do to it's ability to dissipate heat...
Thanks, Shannon
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 05-21-2011, 11:02 AM
David's Avatar
Paint probably won't stay on anyway even if it's exhaust paint. Just take it off and bead blast it.
Old 05-21-2011, 11:58 AM
HFR_Racer's Avatar
I painted mine with VHT super high temp and it held. You need to follow the paint directions though and bake it in the oven between stages. Mine has been on for two years now. Its the highest temp paint they have. Similar to header paint but this stuff is thicker. Usually header paint is pretty thin.
Old 05-21-2011, 12:38 PM
+1 on the VHT
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 05-21-2011, 01:07 PM
Tinkering Pays!!
mooney265's Avatar
thanks on the VHT. Can I paint this VHT over the surface rust, or should I take it somewhere first and bead blast?
BTW: I can't seem to locate the "super" high temp... only High Temp... Is there actually a Super High Temp?
Old 05-21-2011, 06:20 PM
Tinkering Pays!!
mooney265's Avatar
I went ahead and ordered the "flame proof" version...
thanks!
Old 05-21-2011, 06:29 PM
After the next project
x98boardwell's Avatar
Don't paint that piece as those are cooling fins. It may not effect it a bunch there is a way cleaner look... make it look like the picture you have above. I would media blast that section, make it look brand new and then powdercoat the other portion. It is an easy job if you happen to already be doing your valve covers.
Mine was rusty as well and now it looks brand new... with some color.
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel
Old 05-23-2011, 07:05 AM
wcc wcc is offline
wcc's Avatar
+1 Sorry for the crappy cell phone pic...
Bill
997.2
Old 05-25-2011, 03:06 PM
