Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Turbofrog
smurfbus's Avatar
How much boost do you have cruising on highway?
I fixed my MSD installation and now I have IIRC 1psi at 3000rpms = 60mph and at 80mph the turbo is really spinning as feathering the pedal the cruise is at 3psi and slight press on the pedal to keep it going gets 10PSI !!!
I don't know which hybrid it is but before the boost was much more taimed. Fixing the MSD installation feels like swapping in a much smaller AR turbine?
This is the turbo on the car
Which turbo is this 5327 101 5091 on the kompressor housing
I have 0.5 bar at 2000rpms on 4th gear now.
What do you guys boost on highway?
Old 05-29-2011, 01:49 AM
Chain fence eating turbo
Me, 0. That sounds weird. Granted, it makes boost nearly instantly if I floor it regardless of speed or RPM on the highway to a degree.
Old 05-29-2011, 06:10 AM
torresmd's Avatar
I have slight boost around 1 psi when cruising at 80mph. I figured that was normal just the turbo spinning freely and was normal.
1986 930 Slant nose Black/black RUF
2004 996TT Gaurds red/Black EVO GT 660
2001 Ferrari 360 Spyder Rosso/Tan
1969 Carrera Widebody TurboKraft Custom (Mexico Blue)
2001 E39 M5 Imola/Black-red interior
Old 05-29-2011, 06:41 AM
Crotchety Old Bastard
RarlyL8's Avatar
Optimally you will have zero boost while cruising at any rpm and any speed on flat ground.
Many things will contribute to the turbo seeing load at speed. Gearing, timing, fuel, drag, etc. I know a car is tuned for optimal performance and fuel mileage when you can see vac at highway speeds and an instant tip-in to boost the moment the throttle is tapped.
Old 05-29-2011, 07:00 AM
Ken911's Avatar
Do you have a mechanical boost gauge or are you using the electrical one in the dash?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 05-29-2011, 07:08 AM
Depends on where you're taking the reading, before or after the throttle body/butterfly. There is a pressure drop across the throttle body especially when it's only open a crack during steady cruise.
Before it in the intercooler or stock recirculation blow off manifold like a stock car does for the origonal boost gauge you'll see a little pressure that just makes the needle move a hair from the spinning turbo making some pressure at steady cruise.
After the throttle body in the intake manifold like most VDO mechanical boost gauges that are plumbed into the brake booste vacuum line you will see a slight vacuum at steady cruise on level ground or zero on a boost gauge that doesn't also read vacuum.
Old 05-29-2011, 07:34 AM
Turbofrog
smurfbus's Avatar
It's taken from the kokeln IC near the blow off port. Tial is in the same line.
I have a mechanical VDO in the place of the clock.
Gearing is shorter and timing should be nicely advanced plus I run 15AFR on cruise on 93.5 oct. It's just strange that I only changed ignition system magnetic pic-up ppolarity and widened plug gap (ok, new distributor cap and rotor). Before IIRC I did not see any boost on cruise
Old 05-29-2011, 09:11 AM
wwest's Avatar
Boost pressure when not needed, moderate throttle, is WRONG...!
Poor FE and early turbo demise.
Low exhaust flow/pressure along with wastegate opening should be enough to prevent that.
Old 05-30-2011, 10:02 AM
Ken911's Avatar
OK i remember a while back one of the people here who has a shop mentioned something about the timing and flame propagation into the exhaust. Something about if it's retarded too much the flames from combustion blow into the exhaust system before combustion is complete. This would cause more heat and boost during cruise. My memory is pretty foggy on this and it was a couple years back. This might jog someones memory with all the details. Tried searching and couldn't find it.
Old 05-30-2011, 02:13 PM
"0" while cruising.
Old 05-30-2011, 03:36 PM
Tinkering Pays!!
mooney265's Avatar
2/10 BAR at 75 MPH on mechanical 935 Gauge...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 05-30-2011, 04:37 PM
Turbofrog
smurfbus's Avatar
Mooney: Does it spool very eagerly with a little gas pedal? Mine is about 3/10 BAR but instant 0.8 BAR when I move the pedal a little at 80mph.
My timing is on the upside of the scale so it's not that it's burning in the headers IMO. I think the turbo hotside is too small for my combo of B&B headers, free flowing dual out, 964 cams (don't know the timing), tial48 w/0.8bar spring, some K2x hybrid, closer gearset, plugs at 0.04 (before they were 0.028).
Old 05-30-2011, 09:02 PM
Tinkering Pays!!
mooney265's Avatar
Yes on quick spool at 80 mph. And, I too have 964 cams; 1.0 BAR; B&B headers; Hooligan; K27HF; but now have stock 9:38 gearing [used to have 8:41]. My timing is stock..... and hitting 2,600 rpm at 75 mph...
Old 05-31-2011, 06:27 AM
Turbofrog
smurfbus's Avatar
I measured my backpressure before turbo and it's not bad at all. On 3rd gear WOT it's only about 1.3bar max and about the same as the boost (0.1-0.3bar) on cruise on highway?
I will try some other logs later but I thought it would be much higher? I haven't calibrated the MAP yet (used 1.6V for atmo and 5V for 2bar) so it might read wrong?
Old 06-12-2011, 08:52 PM
nreed's Avatar
I'm definitely in vacuum...20-30 cm Hg. At 100MPH maybe .1 bar. You can see my setup below.
Norm '86 930
DTA P8Pro ECU - Synapse BOV - 60# Siemens inj - K27HF - Dual GHL - Kokeln IC - Elgin SC330 cams -
HRE 560R 8.5x18 ET25 11x18 ET0
https://flic.kr/p/nVgoAC
Old 06-13-2011, 02:45 PM
same here vacuum at cruise, as soon as you tip in though....
Old 06-13-2011, 03:56 PM
Turbofrog
smurfbus's Avatar
I just checked the last log and the pressures are accurate. Same 1.2 bar on 3rd WOT at 5000rpms on my gauge and the innovate LM-2 log (1.2bar backpressure at about 0.8 bar IC boost pressure). So it seems it does not rob too much power but the hot side is just too small for continious higher speeds. It does spool fast so it's kind of nice on city limits even though it tends to light up my 315 tires on first if I'm not carefull (need to short shift) on WOT.
Or can anyone tell me why this is happening if it's not the size of the hot side.
Old 06-13-2011, 08:10 PM
Turbofrog
smurfbus's Avatar
Took the turd out and it says K27, 7200R on it so what gives?
Old 06-15-2011, 09:32 AM
To add to this, my gauge reads anywhere from 0.4 - 0.6 on the VACUUM side.
Old 06-15-2011, 10:01 AM
Turbofrog
smurfbus's Avatar
Anyone with 7200 having these cruise boost issues?
Old 06-15-2011, 10:13 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
