Difference in SC Heads VS Carrera Heads
So I had a set of SC heads that may not be coming back to me...... A story involved... I was looking at the valve sizes & port sizes of the SC heads & the Carrera heads. The Carrera heads have just a touch more intake & exhaust port sizes than the SC Heads. Is there any other difference in comparison?
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 05-28-2011, 10:24 PM
Forced Induction Junkie
WERK I's Avatar
Originally Posted by Akila View Post
................................ The Carrera heads have just a touch more intake & exhaust port sizes than the SC Heads. Is there any other difference in comparison?
Correct. The 3.2 heads breathe better than the SC heads by a small margin.
The intake and exhaust port studs different. The 3.2 heads got a reputation of poor valve guide life. Deserved or not, seriously consider having guides replaced if their status is an unknown.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 05-29-2011, 04:50 AM
3.2 heads
Is this a good upgrade with sc cams for our motors? Thinking of collecting parts for a top end rebuild. thanks Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 05-29-2011, 04:58 AM
WERK I's Avatar
IMHO, yes. It's going to require some port matching on the CIS intake manifold/injector blocks and judging from other posts on this site, it is not an easy process. You could go with CNC machined aluminum blocks available from a number of shops. On the other side of things, the exhaust ports should be matched with another style of header. Larger header primaries are in order for the 3.2 heads.
Dave
Old 05-29-2011, 12:43 PM
spence88mph's Avatar
Or... might be the right time to go EFI!
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 05-29-2011, 02:11 PM
If anyone has interest in some Turbo Kraft injector blocks that have been slightly bored to match SC heads, keeping the CIS. I have a set that I will be sellling. I will be going EFI. Thanks for the responses!
88' 930
Old 05-30-2011, 04:32 PM
