Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
andrew15's Avatar
Correct turbo oil feed line?
I have an 86 930 that I'm finishing the rebuild on and have a couple of questions regarding the turbo oil feed line.
Basically it looks like I have a mix of systems (I bought the engine in boxes after a melted piston and may not have gotten all the correct lines...)
- I have a line that looks like it fits on the front pressure sender unit, crosses over the front of the engine and drops to the turbo.
- I also have the rear banjo bolt with the 9mm restrictor ball, but am missing the hose to run from this rear stand-off to the turbo.
Is the rear sender with check valve the preferred way to feed oil to the turbo ( running a K-27 and can make up an an-4 line to replace the missing one)?
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 06-01-2011, 05:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Andrew
A banjo bolt with a male 4 AN at the rear restricted fitting is the most used. With the restrictor it allow some flow adjustment by addling a light spring on top of the 9mm ball if needed.
Here are a couple pics:
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, K27S, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 06-02-2011, 11:48 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
The factory line is a hard line from the check valve and light switch to the #1 intake and the shroud screw, then rubber line to the top of the turbo.
Why would I want to use AN-4 fittings and steel mesh wrapped hose when the proper oil line is still available?
Bruce
Old 06-02-2011, 06:20 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Bruce,
My reply was in response to Andrews questioning the use of a 4 AN line. Total cost of line, fittings, seals, banjo and, oil inlet flange is about $60-$80.
The factory turbo oil feed hard line PN# 930 107 125 03 - $116
The turbo inlet flex line and flange PN# 930 107 124 01 - $99.50
So the $125, or so, you save will get you and the wife a decent dinner out, a couple drinks, and probably get you laid afterward. The wife is happier and no longer *****ing about all the money you blow on 930 parts so now you can go order more parts without a hassle.
Cole's old bull young bull theory
Old 06-02-2011, 08:05 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
7.0:1 > 11.3:1
Haha, good response Cole. Alternately Andrew could ask me to give back the line he GAVE me!
Old 06-02-2011, 09:06 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
lol.. along with all that the AN fittings and braided line look 10x cooler.
Old 06-03-2011, 07:33 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Toofah King Bad
Rasta Monsta's Avatar
. . .and the hard line can't really be properly cleaned out.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-03-2011, 08:03 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
stevie 77 930's Avatar
Andrew,
I have only seen a picture of the Turbo Oil feed line that crosses the front of the fan in the service manual. I have yet to see it on any turbos posting here. Almost everyone seems to have the oil feed line that originates at termostat and runs under the intake manifold. Just currious, is there a part number for that line that crosses the fan ? The factory line seems to be the easiest route...
This is what i typically see:
1977 930 GP White
2011 BMW 335 D (thats right a Diesel 425 ft lbs of torque)
1973 1/2 911 T GP White (sold way too soon....ugh)
1976 911 S Silver (my very first 30 years ago)
Old 06-03-2011, 10:48 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Happiest when Tinkering
gsmith660's Avatar
The one you are talking about from the service manual is the early oil supply line and is NLA as I tried to source all the parts when I did my turbo install the best alternative is to get the kit from turbokraft as it has all you need for a lower price than the factory stuff. The banjo was difficult to source and the wait is long for the check ball housing from the factory and the 9mm ball is NLA from Porsche AG when I ordered from pelican thanks to Ben at M&K to send me one.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 06-03-2011, 06:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
I have a whole bag full of balls, I mean, if anyone needs a 9mm restrictor ball let me know.
Cole
Old 06-03-2011, 07:09 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
andrew15's Avatar
Thanks Guys!
That help a lot.
Jim -
So, umm... are you back yet?
I'm heading out there today to check the lines that I have, but I think the seller kept the updated line and gave me the old style line.
AM
Old 06-04-2011, 07:03 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
7.0:1 > 11.3:1
Yup, I'm back from vacation Andrew but no plans of going to work today. If you need it you'll have to come by my house and p/u otherwise I'll leave it with your car on Monday.
BTW, there is only one style of line. There is however two components which make up this line feeding the turbo. Perhaps the short section which bolts to the top of the turbo is confusing you.
Old 06-04-2011, 08:13 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
andrew15's Avatar
Thanks guys - got it sorted out. It turns out I did have the correct line, but the hose was rotated so it didn't seem to match up. A little rotation of the hose and a bit of finessing to get it uner the CIS system and all is good.
AM
Old 06-04-2011, 01:25 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
BoxsterGT's Avatar
Porsche Crest
andrew15-
I am curious if you might have a minor oil leak at this hose where you were able to rotate it.
When crimped the hose normally does not rotate on the tube. If it does, usually its become hard and has lost its ability to seal & will start to leak.
Len
Old 01-10-2012, 06:18 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
andrew15's Avatar
Not yet....
Old 01-10-2012, 09:01 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
If you need to source the 14MM banjo bolt, Speedway Motors has one with a -6AN fitting on it. It is apparently used with some Power Steering applications for street rods. The link is Banjo Fittings for Power Steering Pump - Speedway Motors, America's Oldest Speed Shop . Hope this helps.
Tom
1972 911T (with 3.2 Motronic), 1985 930 -Undergoing EFI Conversion, 2002 Turbo X-50
Old 01-10-2012, 10:55 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
BoxsterGT's Avatar
Porsche Crest
Had a chance to build a fixture so I can now Re-Hose these turbo oil feed lines...........
So now there is an alternate source......$35 plus shipping to do yours. Also available on an exchange basis.
Len at Autosportengineering dot com
Old 04-06-2012, 03:10 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
$35 shipped for the feed line? That's a helluva deal! When I bought my turbo, the motor had @ 2k on a rebuild. There were leaks so my mechanic looked at the motor and pulled it. One thing led to another and he shows me the feed line the previous builder used. The guy used part of the old hard line, but replaced the rubber hose with fuel hose and hose clamps.
Bryan O.
77 930
04 RX330
05 E55
Old 04-06-2012, 04:32 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #18 (permalink)
BoxsterGT's Avatar
Porsche Crest
Thanks for the free bump WPOZZZ. You are close but not quite correct.
I am offering to RE-HOSE your original turbo oil feed line for $35. The hose is $25 and the (2) crimp sleeves are $5ea.
You must send me your original and pay the shipping costs. Its about $8 by Priority Mail, and typically takes 2-3 days coast to coast.
I have a couple spare lines, so I will re-hose them & offer them sometime soon on an EXCHANGE basis.
Email me only.
Please no PM's, its usually full and I cannot send photos via PM.
Go to my user name and click on send email.
Len
Old 04-06-2012, 04:57 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #19 (permalink)
I know my mechanic has another rebuild coming up, so I'll ask him if he needs the line re-hosed.
Bryan O.
77 930
04 RX330
05 E55
Old 04-06-2012, 05:12 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #20 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
