-   -   Getting ready for my efi swap (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/612139-getting-ready-my-efi-swap.html)
Ken911 06-03-2011 06:13 PM
Well i figure i might as well start a thread for my efi swap over. it will be very long in coming. I have started to collect the parts. I have several sets of cams haven't figured out what to do yet but most likely will send the 964 stock cams out and have them ground to gt-2 evo and a scavenge pump drive added. I am planning on a ms-3 system with coil on plug twin plugged. I am in the middle of trouble shooting an ignition problem now and almost ready to just give up and pull the whole mess out and start early. The heads are out for porting now just got a couple pics yesterday. Haven't decided where to send them for twin plugging yet. The 3.2 intake is sitting in the garage.
http://forums.pelicanparts.com/uploa...1307149943.jpg
http://forums.pelicanparts.com/uploa...1307149974.jpg
http://forums.pelicanparts.com/uploa...1307149998.jpg
911nut 06-04-2011 05:02 AM
Looks like fun stuff. Good luck with the conversion.
willtel 06-04-2011 06:18 AM
I'm in the same boat. I have a 3.2 intake and have been selling off my CIS parts to fund the project. What ecu are you planning to use?
Ken911 06-04-2011 02:47 PM
Megasquirt 3 with the xpansion card vw coil on plugs just like the one turbo nut did.
Ken911 06-30-2011 04:23 PM
Got my heads back from getting the valve job done and porting finished. Now who is the most reasonable for twin plugging them? I had him assmble them to check spring heights and pressures. but not install the seals. so that i can take them back apart for twin plugging them.http://forums.pelicanparts.com/uploa...1309476158.jpg
http://forums.pelicanparts.com/uploa...1309476203.jpg
Ken911 07-01-2011 07:11 PM
so who is the most reasonable for twin plugging them?
E-man930 07-01-2011 07:18 PM
May want to aak over in the 911 engine building thread... I don't have anyone to recommend from experience but I would use Mike @ JB Racing because of their track record and proximity to me.
Ken911 07-01-2011 07:21 PM
ok i'll check over there
sundevil64 07-03-2011 06:40 AM
I used Craig. He is on the forum "cgarr". I was very happy with the work and service.
Here is a link to my actual heads being twin plugged.
YouTube - ‪Twin Plug Porsche 911 Cylinder Heads‬‏
I thought he was reasonably priced. He was referred to me by another Pelican.
Good luck with your project.
Ken911 07-03-2011 11:00 AM
ok thanks!! It seams every one uses 12 mm plugs for the second plug. what plug do you actually use that works with the w3dpo in the stock location?
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
