What oil?
Hi everyone ,
I know it maybe a contentious subject but do any of you guys have an oppinion on the best engine oil for a 930 turbo 1983?
Im looking to do an oil change some swear by mobil some shell ,what do you guys think ?
Old 06-08-2011, 02:50 PM
brad penn 20w50
87 carmine red 930 | 57k | B6 modified IC | GHL headers | custom exhaust | VEMS EFI | carrera intake w/ flipped TB | LS2 coils | EBC | K27-7200 (soon to be replaced by GTX3071
Old 06-08-2011, 04:14 PM
I use Brad Penn.
1987 GP White 930
1977 Ford Bronco
89 930.
Benny771's Avatar
Old 06-08-2011, 04:22 PM
Registered Driver
Helmsy's Avatar
Daily driver, occasional track day or full race spec.? Factory oil separator still installed?
20w50 is good for a daily driver but remember to always get the temps up and give it the occasional WOT while at operating temp. otherwise you will more than likely get the dreaded milky substance others have posted about.
Also inspect the oil you remove as it will give you the best indication of how your engine and oil system are performing. I like to also drain the turbo oil tank too.
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 06-08-2011, 04:36 PM
j930's Avatar
+ 1 on brad penn
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 06-08-2011, 06:05 PM
mark houghton's Avatar
Contentious?? Man, that's an understatement.
Easily available Valvoline VR1 Racing 20/50.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 06-08-2011, 06:48 PM
Large Member
krasuskyp's Avatar
another Brad Penn'er
and
I ALWAYS get it warm, anytime it's started up
AND
I ALWAYS get it WOT once warm at least 1x
8-)
still get some milkiness under the filler cap - annoying, esp 'cause I never don't run the bejeezus out of it...
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 06-08-2011, 06:55 PM
Mobil1 vtwin fully synthetic 20w50.
Old 06-08-2011, 07:48 PM
Originally Posted by im4duke View Post
mobil1 vtwin fully synthetic 20w50.
+1
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 06-08-2011, 08:13 PM
Brad Penn grade 1 20-50
or the Valvoline VR1 their about same , google them
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 06-09-2011, 03:52 AM
Chain fence eating turbo
I've been using Valvoline VR-1 and the main/rod bearings looked perfect after 5 years of use from the previous rebuild.
Old 06-09-2011, 06:53 AM
Porschephd's Avatar
I still use good old Castrol 20-50 and change it every 3K miles like clock work.
Stephen
94 3.6Turbo 6-speed AWD
Old 06-09-2011, 07:14 AM
HFR_Racer's Avatar
Porschephd:
Which Castrol blend are you using (full synthetic)? How many miles have you run using Castrol? Are you running Castrol in all of your Porsche's? Also, how are your cam lobes looking after significant mileage?
I'd like to hear about your experiences with this oil.. I'm running Mobil 1 Turbo Diesel Truck 5W-40 and everything is looking very nice inside thus far. 90k miles on the clock. I've been buying it from Amazon and using free shipping The previous owner also was running Mobil 1 full synthetic.
Thank you,
HFR_Racer
'87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups.
Old 06-09-2011, 06:04 PM
guys thanks for all your suggestions just to clarify the vehicle is NOT a daily drive vehicle its a sundays and high days vehicle for fun .The oil ive taken out looks dark in colour but not to bad ,i will send pic soon so you can check out .
The oil in there is mobil 1 15w/50 but as its a 930 turbo ive got a few little niggly oil leaks but nothing massive im aware that certain viscosities are better at helping this? additionally im in London UK so our winters tend to be cold and summers sometimes get into high figures which if im honest will most likely be the only time im driving her .I had thought about track days in the future so any updated comments taking into consideration this info would be appreciated .
I dont know if i can getg "pen" oil here in uk?
thanks
Old 06-11-2011, 08:17 AM
im also confused about the fully synthetic argument ?
Driver
Noah930's Avatar
Anecdotally some people have noticed that if you switch from dino oil to synthetic, oil leaks may appear (or worsen). Conceptually the slipperiness of the synthetic is so good, it slips through cracks and crevices that dino oil would not have.
I used to run Rotella, but as I can't find it with the old formulation any more I've switched to the Valvoline VR-1 that was on sale for $2.50/qt a couple months ago. I've got a few cases in the garage for the future. I've also got a case of Brad Penn sitting on the workbench. All 20w-50.
Of note, the regular Mobil 1 is not considered "good enough" anymore. The V-twin stuff is acceptable, but I think it's almost $10/qt.
edit: Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
1990 Black 964 C2 Targa
Old 06-11-2011, 10:16 AM
Forced Induction Junkie
WERK I's Avatar
50%/50% blend of Mobil 1 20-50W/Mobil 1 V-twin 20-50W
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 06-11-2011, 03:39 PM
jayhawk's Avatar
The Pumpkin lives on a steady diet of Brad Penn 20-50. I get it from the Vavoline distributor in KC.
Bob
Past President KCRPCA
PCA National Certified Instructor
1982 930 Track Car "The Pumpkin"
2002 996tt X50 Lapis Blue Street Machine
Old 06-11-2011, 04:21 PM
Mobil 1. Let's the war continue...
Old 06-11-2011, 05:13 PM
