Old 07-08-2011, 03:54 PM
For those that are interested, I finally got my re-worked fuel lines bead blasted and back from the plating.
I also ordered some metric hose fittings, adapters and -6 hose fittings as well as 20 feet of Aero-Quip Starlite hose.
Just an FYI for anyone deciding to do something similar. The gold and black fittings in the pics are not correct for the Starlite hose. These fittings are "cutter" type and are not compatible. These were sent to me by mistake and will be replaced by the correct fittings.
I've also ordered some extra fittings to run new fuel lines from the tunnel to the rear fuel pump up to the manifold and back.
Here are some pics....
Old 08-21-2011, 03:52 PM
The oil lines coming from the thermostat back got the same treatment.
Old 08-21-2011, 03:55 PM
Strygaldwir's Avatar
Outstanding!
Old 08-21-2011, 06:39 PM
sjf911's Avatar
What material are you using to braze (filler, flux) these and what type of torch/heat were you using?
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 08-22-2011, 08:05 AM
I use harris saftey-silv 56. It is a silver brazing rod.
I also use it with the harris stay-silv white flux.
Don't confuse this with silver soldering as this needs to get up to about 1200 degrees for it to flow.
oxy and acetyline is a must.
Old 08-22-2011, 08:35 AM
E-man930's Avatar
Very nice work!
Are you cad plating these yourself?
Old 08-22-2011, 10:03 AM
Thank you.
I have them done at an industrial plating company. You will never get a durable high quality finish with a home plating kit. At least I don't think you will.
I do however prep everyting myself.
Old 08-22-2011, 11:07 AM
Here is a pic of "some" of the stuff I had plated........
Old 08-22-2011, 03:31 PM
David's Avatar
A man after my own DIY heart. Very very nice!
2014 Cayman S
2011 Cayenne Turbo
Old 08-22-2011, 05:35 PM
Champagne on Beer Budget
HelmetHead's Avatar
Originally Posted by david View Post
very very nice!
+1
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 08-24-2011, 07:54 AM
totle's Avatar
Looking awsome :-)
Is this plated with a DIY kit or professionally ?
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 08-24-2011, 01:46 PM
R.I.P.
drmatera's Avatar
Thank you.
Originally Posted by totle View Post
Looking awsome :-)
note reply #28
Old 08-24-2011, 02:17 PM
