02fly's Avatar
which optima
I know there are alot of threads on this but I was wondering what part number I need. I called my battery guy and he wanted to know which one I wanted.
Old 06-08-2011, 10:32 AM
Garage Queen
PorscheGAL's Avatar
Redtop
Part Number Red 34/78
Model 3478DT
CA 1000
CCA 800
RC 100
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 06-08-2011, 12:16 PM
E-85 sippin drunk
turbobrat930's Avatar
I will tell you this.... ALL of the red tops that I have owned were JUNK. In both of the cars that I had the red tops in, I had to replace both of them twice. And one of the cars had a battery cut off switch in it. There was no partasitic drain on either battery.
I will also tell you this. I had built a huge rock crawler Jeep with a Lt-1 vette engine in it. I had two yellow top Optima batteries in it. They were wired in parallel, and I had the ability to cut one of them off to use for the winch if I needed to. Both were hooked up to a battry cut off switch, and I had the batteries for almost 4 years. ZERO problems out of either battery.
The blue tops are a deep cycle marine style battery. I would stay away from those.
Just a little info... hope this helps!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 06-08-2011, 12:24 PM
Garage Queen
PorscheGAL's Avatar
I've had a red top in the 930 for 2 yrs with no problem.
Stephanie
Old 06-08-2011, 12:26 PM
Unless you drive the car daily I wouldn't buy an Optima. Something changed with them about 5-6 years ago and they became very needy. If you don't charge them regularly they lose voltage and won't start the car.
I have an Optima Yellow Top in my Bronco that has been replaced once despite only being used to test wiring during a restoration and it was charged up after each use. The new one is ten months old and will not start the truck if it sits for more than 5 days at a time. The wiring and charging system is new and there is no drain on the battery when the ignition is off. The battery just sucks unless you use it all the time.
Look into an Odyssey or a Deka.
1987 GP White 930
1977 Ford Bronco
Old 06-08-2011, 12:32 PM
E-man930's Avatar
Almost any of the. m will do, I would also pick up one of these to make the install a breeze and super clean... ==> Optima Battery Mounting Tray Kit for 74-89 Porsche 911 | eBay
Old 06-08-2011, 12:42 PM
02fly's Avatar
Thanks for the help my battery guy was also steering me towards an Odyssey but they are a little more money but if the optima's have problems than the Odyssey may be the way to go
Old 06-08-2011, 01:29 PM
I was just going to suggest looking at the Odyssey. I have heard good things. Albeit, it requires a different charger to charge it versus a trickle is my understanding. A friend has one in his 912 with zero problems. The feature I like about it are the size, weight, and shelf life. It will be the next racing battery for me. They are a little pricey though, but so is about everything else for these cars.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 06-11-2011, 05:16 AM
Stranger on the Internet
patkeefe's Avatar
I had a red top. It was 12 years old, I changed it to a yellow top, simply because it was 12 years old. The red top is still good, and charged. I use it for 12V DC experiments. It is now 15 years old.
Patrick E. Keefe
78 SC
Old 06-11-2011, 07:58 PM
