1986 930's Avatar
Dieseling on shut down
As far as I know I have a stock CIS System, Euro Fuel System. After running the car for a bit, the car diesels when I shut it down. ( turn off the key and it continues to run for a bit, very roughly) When I run the car around town and start and shut it down it only does it on the first shut down. Otherwise it runs great. So I have two questions:
1) What is causing this?
2) Is this bad and I am destroying my car little by little?
Thanks,
Mark
Mark
1986 930 Ultra-Smith RUF Slant Nose conversion, RUF VB, K-27 HF-S, B&B Headers and Exhaust, RUF Short Shifter, RUF Interior
Old 06-12-2011, 04:08 AM
beancounter
jwasbury's Avatar
There is something called the ignition delay relay. This maintains power to the ignition system for a few seconds after you shut off the key. The fuel pumps power is cut, but the car runs on for a few moments to burn off the last bit of fuel in the injection system. From your description, its possible that what you are calling dieseling is actually the normal ignition delay.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 06-12-2011, 04:59 AM
Registered Driver
Helmsy's Avatar
It could be the injector(s) not holding pressure enough after shutdown and leaking.
Check your fuel pressures. Raising the system pressure can stop it occuring however if it isn't the usual delay-relay shutdown then more than likely a leaky injector.
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 06-12-2011, 05:26 AM
1986 930's Avatar
Thanks for the replies.
If the injector(s) were leaking, wouldn't I smell fuel?
Mark
Old 06-12-2011, 08:40 AM
Crotchety Old Bastard
RarlyL8's Avatar
No you won't smell fuel because they are leaking into the cylider. The delay relay is in place to allow any unburned fuel to do so, meaning that if the fuel system is working perfectly there will be no run-on.
Unfortunately the only way to find a leaker is to pull the injectors and test them. If this is not something you want to do the relay can be jumpered/disabled. There has been a few threads on this phenomenon lately and one has the ID# for the relay and which ports to jump.
Old 06-12-2011, 10:41 AM
1986 930's Avatar
Is it something to worry about beyond just annoying?
Mark
Old 06-12-2011, 11:15 AM
