Crotchety Old Bastard
RarlyL8's Avatar
Time to get out the gages and check your pressures.
System pressure should be ~95+psi, cold ~35psi @ 70F, and warm ~50psi. First and foremost is your system pressure. If the ballooning was indeed caused by a blockage then the system pressure should be down off spec.
Old 06-17-2011, 07:39 PM
I didn't get time to put gauges on it, but I did mess with the mixture screw and richened it (clockwise). It started and ran, albeit not very well, but it ran. I adjusted the screw more, but it doesn't "click" anymore. Should it? I think it is till lean. I need to see what the control pressure is and also put an LM1 on it. I didn't have the tailpipe adaptor and there is not a bung on this exhaust.
John- I blame and thank the longhood boys of Austin
84 911 Carrera w/ 930 t/p,efi'd,dizzy free,HFS turbo[/COLOR], 78 930 RoW no option sunroof coupe, 64 Corvette roadster, 71 911T, 73 911E, 67 Bronco survivor. 71 FJ40, 2001 Boxster
"Illegitimi non carborundum"
Old 06-19-2011, 09:15 PM
I checked the resistance on the WUR and it is 27ohms. I think that is too high. Should I replace or dismantle and clean?
Old 06-29-2011, 09:21 AM
