LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
E-85 sippin drunk
turbobrat930's Avatar
getting rid of the engine mounted oil cooler... How I did it...
So, I needed a Cam Position Sensor (CPS) in order to run sequential fuel injection on my car. In order to do that, I needed the 4,5,6 cam, as the other already had the scavenge pump attatched, and at the time I started my build, Clewett was not making the aftermarket scavenge pump/ CPS combo. So, I had to get rid of the engine mounted oil cooler, and as I lunched my engine, if I wanted to keep it, I was going to have to buy a new one anyways. ( I dont trust ultrasonic cleaning.... not as expensive as these engines are!)
So, I liked the idea of adding the 993 oil filter console and gaining not only the room to install the CPS, but the addition of an extra oil filter. I was able to aquire a 993 oil filter console in trade for my used engine mounted oil cooler. Now, in taking out the engine mounted oil cooler, it was advised by me that it was a must to add a second, fender mounted oil cooler up front. The search was on. DonE had very good success with a pair of Fluidyne oil coolers. I went to the Fluidyne website and looked around. With the demensions that I had to play with, I found a model they had would work. ( It might be different in other cars, as I have a custom Carbon Fiber GT-2 front bumper). I found the oil cooler about the same price at different vendors, but Summitt Racing also carried the cooler, and they had them in stock. Since we have a retail Summitt Racing store just South of Atlanta, I wanted to put my hands on one of the coolers before buying them. I drove up to the Summitt store, and placed my order for two of the coolers, -12 SS Braided line, fittings, and two oil cooler fans. Once I had the parts in my hands, I was amazed at the quality of the Fluidyne Oil Coolers! They were a work of art, and I hated that they would be in a place that they could not be seen.
The Fluidyne Oil Coolers have -12 inlets and outlets, and a 1/2" NPT port for a sensor, etc. They fit perfectly in the space right behind the headlight bucket and are about as large as I could fit in there, and still have room for fittings, etc. I also looked for fans, and since I was at Summitt Racing, all they had in stock was a company called Derale. That company had a fan that would match my needs. An 8" fan, that was reversable, and flowed 500CFM. It fit on the cooler about as good as you could ask for without having a shroud. If you need to reverse the flow on these fans, you dont just switch the ground and power wires. On these, you actually unbolt the fan from the shaft, flip the fan, and bolt it back on. This makes the fan blades work as they were designed to, and you get the true CFM rating wether they are reversed or not. I wanted the fans bolted to the back of the oil coolers (tire side), but I did not have the clearance to run them there, as the tires would hit the fan anymore than a half radius turn. The fans were mounted to the front of the oil coolers, and ran in a pusher configuration. I hooked one of the fans up to a 12v battery, and WOW, they really put out some serious air! My ECU will turn these fans on or off, depending on a preset value.
Now, running the 993 Oil Filter Console presents another problem: the Aluminum pipe that is part of the engine mounted oil cooler, and supplies the engine with oil from the oil tank via the "s" hose is now gone. I located a solution at Smart Camber/ Jerry Woods Enterprises. They have a Aluminum fitting that bolts to the case, and turns into a -16 fitting. They also have a pipe that screws onto the -16 fitting and ends right where the stock Aluminum pipe did on the oil cooler. The problem is, is that these two parts alone are close to $250.00, which at this point, I did not want to spend. A good friend of mine, who is way smarter than I at the machining or parts, came up with an idea. He has a Gorton milling machine which also has a tracer attached. We mounted the engine mounted oil cooler to the table of the milling machine and began the setup to attempt to reproduce the portion that includes the oil supply tube. As you can see from the pictures, my friend really came through. The parts look awesome!!! At the time of these pictures, we still had a little finishing work to do on them.
If you go with the 993 oil filter console, you will need to modify your existing engine cooling shroud, or purchase one that does not have the duct for the oil cooler. I chose to modify my existing one. I took a cut off wheel and cut the raised portion out of the shroud. I then took a small piece of shet metal, cut and formed it, and rivited it to the bottom side of the shroud. Kinda like the stock piece of sheet metal that is already there, I just added to it. I then used a little body filler to smooth out and blend the upper portion of the shroud, painted it, and then waxed it. You will also have to fabricate up a small piece of Aluminum to block off the airflow along the side of cyl #6. I cut a pattern out of a 12 pack of Coke-Cola box, and used that to get my final shape.
I posted this for one reason, for others who are contempating this, to show what is involved. DonE stated that with the dual Fluidyne oil coolers, he hardly ever saw oil temps above 100C and that was in the middle of Atlanta traffic in the middle of the hot GA summer. If you do not have EFI, or an ECU to control fan turn on or off, you will also need to source a fan controller, which are out there and not too much money.
Here is a parts breakdown and the prices as of May, 2011:
(2) Fluidyne Oil Coolers Part # DB-30417 $299.00 each
(2) Derale Brand Oil Cooler fans Part #16508 $79.99 each
(15) feet of Russell brand -12 SS Braided hose $110.00
(4) various AN fittings (90deg, 45deg, straight) $100.00
(1) 993 facoty oil cooler console part # 993.107.205.0r
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 06-17-2011, 05:02 AM
After the next project
x98boardwell's Avatar
Nice work bro.... Keep up the good work and get that damn thing running will you
Previous cars:
1987 930, 1975 914 2.0, 1989 944 Turbo S, 1991 964 Targa, 2004 996TT Convertible, 550-6 Spyder with a 2.4 liter twin plug "S-spec'd motor"
Current cars: 2006 Cayenne TTS, 1991 964 Cabrio, 1997 993TT, 1984 Jeep Grand Wagoneer
Old 06-17-2011, 07:06 AM
Chain fence eating turbo
Cool
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 06-17-2011, 07:37 AM
Metal Guru
911nut's Avatar
Great design and fabrication job. Keep those pictures coming!
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 06-17-2011, 07:55 AM
Large Member
krasuskyp's Avatar
slick / sick
soooooooo niiiiiiiice
great work, tx for sharing
Been waiting yearses for you to debut your car! You gotta be jonesin! 8-) Sounds like, maybe, just maybe... you're getting maybe close-ish? Fingers crossed...
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 06-17-2011, 08:22 AM
Ken911's Avatar
So why didnt you just put a 25cent screw in the air pump wheel and a 30$ hall sensor in the air pump housing? and keep the engine oil cooler?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 06-17-2011, 09:58 AM
Octurbofest should be in Michigan this year guys, please, so I don't have to beg my wife to leave town an instead all these cool cars will come to Michigan.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 06-17-2011, 01:53 PM
E-85 sippin drunk
Well, to be honest Ken, I did not want to have either the front oil cooler or the engine mounted oil cooler ultrasonically cleaned. I just dont trust it. And if I had to buy new ones, i thought maybe I can improve on the cooling capabilities. I also liked having the extra oil filter. It just seemed like a win/win situation...
I have also learned from others bad experiances, that the $30 hall sensors just dont cut it. I bought two sensors from Honeywell. They were not cheap, but they will be a much better sensor....
Schnele, I want to bring the car upto West MI at the end of July for a car show and magazine shoot... However, it may not be ready by then.... I still have a few small items to address. But it is VERY close... maybe 3 more weeks (if it all works out??)
Brad
Old 06-17-2011, 03:29 PM
I have the state covered, my main home is in Rochester Hills and my Cottage is on Lake Charlevoix so I can get to just about anywhere on the lower peninsula and not be too far from home.
Lincoln Phillip
Old 06-17-2011, 03:48 PM
E-man930's Avatar
Thaks for the post! This is on my list of things to do next go around.
Old 06-17-2011, 05:55 PM
Lincoln,
I am Brad's brother Bryan. We are far apart now but we are from the Grand Haven, Muskegon area about an hour North of Holland and about an hour South of Ludington in a small town called Whitehall... a small boating community that is on Lake Michigan. This is where we will both be the end of july through the first week of August.
We are less than 2 hours from Charlevoix... I have sailed and drove there many times growing up... great community. When will your car be done?
Regards,
Bryan
Previous cars:
Old 06-17-2011, 06:18 PM
Awesome stuff !!
I am really liking those oil coolers. I need an oil cooler for my fender and these look really nice. Are you going to fab up a rock guard for it?
That tracer mill looks like a fun toy!
Also, I am curious how the end of you oil pipe will be supported.
Thanks for posting, I love the diy solutions!
Old 06-17-2011, 07:13 PM
E-85 sippin drunk
Thanks, The end of the pipe will be supported by a piece of Aluminum that will be welded to the pipe and bolted to the engine sheet metal tin. It will only be about a 5" long piece. it will look good when it is done, and be functional.
As far as the rock guards, I dont know yet.... I ran for years without em..... I might make some after the car is on the road... right now, that is the bigggest goal!!! LOL
Old 06-18-2011, 06:11 AM
