Alan L's Avatar
930 cylinders/heads
Just getting as organised parts -wise as I can before I pull part of my engine down looking for problems. I have a spare set of P/Cs 2nd hand. Just had a look at them. The cylinders dont have the head gasket groove.
What era of the series did they change to gaskets/grooves?
My engine is a type 68 which I think puts it in the 86/87 era. Presumably this has gaskets.
Does this mean my current heads wont fit/seal on the spare cylinders?
If so, can these cylinders be grooved to mate with the heads?
(I find it remarkable Porsche could even contemplate let alone sucessfully seal one of these high performance engines with no head gaskets - mind boggling)
Next Q - where do I find the piston group weights on these pistons. I do have a number on the underside - 97P12+. Is that it?
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-20-2011, 09:02 PM
Banned
FYI: my 87 is non-head gasket (pretty sure they all are from this era) . . .
An interesting observation about non-head gasket engines - Ducati does this as well with their air-cooled models (really surprised me when I saw that for the first time).
Old 06-20-2011, 09:22 PM
Alan L's Avatar
Fascinating. Cant work out why they dont leak - but obviously porsche and Ducati have.
pelican list 930 head gaskets - so what era do they belong too?
Alan
Old 06-20-2011, 09:38 PM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
Alan, you may want to post the question over on the engine re-building section..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-20-2011, 10:30 PM
Alan L's Avatar
Hi ya Todd. If I dont get the info here I guess I can do that. Just the Q is specific to 930s so thought I should try here first. Will see how we go.
Good to hear from you again. Coles post brought me to tears. Wish I was over there sometimes.
regards
Alan
Old 06-20-2011, 11:00 PM
lite75's Avatar
The early 3.0 has sealing rings, the later 3.3 does not. If you have grooves in your heads then you have flame rings, a common modification for head to cylinder sealing in high boost applications.
75 930, 76 930, 83 SC EFI turbo
Old 06-21-2011, 06:07 AM
Alan L's Avatar
Havent got the engine apart yet - so dont know about the heads.
Amazing that they ditched the sealing rings in a turbo/high pressure motor. Any idea why they would go down that track?
Looks like my spare cylinders will be useful after all, if I need them. Hoping not to.
Are the piston weight groups (- + ++) on the underside by the wrist pin boss? I have some numbers under there, followed by a + (on my spares)
Alan
Old 06-21-2011, 03:50 PM
Alan L's Avatar
OK, so this is weird. pelican list head gasket rings for 3.3 engine '78 0nwards?
How does this work?
Alan
Old 06-22-2011, 12:18 AM
All 3.3 have base gaskets. They are a small cooper gasket that is in between the cylinder and case.
Robert
1985 Euro Red Carrera Coupe."SOLD",1985 White Targa Carrera. "SOLD",1977 Yellow 930. "SOLD",1991 Black 964 C4. "SOLD",2002 Silver 996 C4 Cab "SOLD",
2001 Polar Silver 996 twin Turbo
Old 06-22-2011, 06:10 AM
TurboKraft's Avatar
The 1976-77 911 Turbo Carrera 3.0L had a "CE ring" type head gasket, similar to a non-turbo of that era.
The 1978-89 930 3.3L did not have head gaskets -- straight metal-to-metal sealing on precision machined flat surfaces.
The 1991-92 C2T had flat steel shims "gaskets" between the heads and cylinders.
The 1994 Turbo 3.6 had the same metal sealing rings as the 964/993 engines.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 06-22-2011, 08:34 AM
Ok. I just watched a 87 3.3 being built and I saw a small thin copper gasket with cut notches being placed between the head and the base. I'll call the shop to make sure I'm not going nuts.
Robert
Old 06-22-2011, 11:43 AM
Alan L's Avatar
Thanks Chris, but why does Pelican have cylinder head gaskets listed for 3.3 from '78-89? Edit 930-100-908-02-M17
Or is it a pelican error?
Alan
Old 06-22-2011, 11:54 AM
Mix and Match?
Can mix and match the pistons and cylenders from these groups? Say P/C from 76-77 and heads from 78-89? Or P/C from 91 and heads from 78-89?
Old 06-22-2011, 08:40 PM
Certified User
billjam's Avatar
Alan,
The Pelican number 930-100-908-02-M17 is a cylinder head gasket SET, it isn't a set of HEAD gaskets. It's all the gaskets you need to reinstall your heads, i.e. rocker cover gaskets, camshaft housing gaskets and a few other random bits that I can't recall.
The '86 era 930 engines categorically do not have gaskets between the cylinder and the head (unless they have been modified).
Bill
1988 Carrera - 3.6 engine (with ITBs, COPs, MS3X) and a whole set of turbo body panels waiting in the attic.
Day job ... www.sspowdercoat.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 06-23-2011, 03:26 AM
Certified User
billjam's Avatar
Robert
Robert,
The gasket you describe goes between the base of the cylinder and the crankcase, NOT the top of cylinder and head.
Bill
Old 06-23-2011, 03:29 AM
Alan L's Avatar
Many thanks Billjam. You have put me out of my misery.
Alan
Old 06-23-2011, 02:50 PM
