DGW DGW is offline
3.0 turbo and 915 trans
I have a 77 turbo with a 915 trans in it. When I acquired it, it also had an "S" engine in it and all worked fine. I have acquired a 3.0 turbo engine to put in the car. My brother is doing the mechanical work and successfullly attached the trans to the engine and jacked them into the car. When attempting to depress the clutch pedal it would not move. The engine is back out of the car and everything appears to have been done correctly. He is currently researching this.
I talked to a Porsche mechanic who is certian that there is "something" that is special about hooking up this engine/transmission combination, but so far has only come up with the flywheel, which needs to be a 911 flywheel, not a turbo one. We were not aware that there was a difference, but we used the one off the "S" engine anyway because it was in much better shape. I see that the part numbers are different. I learned something new.
The question then, is, what is the secret to making these two work together? i would really like to drive the car.
Dennis
Old 06-21-2011, 09:03 AM
Ring gear
The ring gear may be the issue. That is the removable starter ring bolting to the flywheel.
Old 06-21-2011, 09:31 AM
copbait73's Avatar
My guess is you did not engage the two throwout bearing paws in the slot as you mated the engine and trans.
Old 06-21-2011, 09:34 AM
stevie 77 930's Avatar
This what the 915 looks like in front of a 3.0 liter Turbo. No different than any other 911 motor. With the 3.0 turbo, you use a 6 bolt 911 flywheel, standard 915 clutch assembly and pressure plate. You should also be using the correct clutch cable, clutch fork and omega spring. All of this is no different than what you had with the "S" engine. As already suggested, make sure the fork is engadged in the throw out bearing
1983 911SC
1974 914
2018 GTS
2019 Audi S4
'76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 06-21-2011, 10:09 AM
DGW DGW is offline
Its the 915 ring gear. We are not sure how it could be an issue. Can you say more about this?
Originally Posted by copbait73
...throwout bearing...
Yeah, we thought of this too. Its been checked at least 3 times, in and out of the car. We believe its right. We will certainly check it again before the next assembly attempt.
Originally Posted by stevie 77 930
6 bolt 911 flywheel, standard 915 clutch assembly and pressure plate. You should also be using the correct clutch cable, clutch fork and omega spring...
Nice picture, the trans looks brand new! Mine looks like that out of the car too, although not as shiny. Check on flywheel, clutch assembly etc., all 915.
Thanks for the ideas/suggestions.
Dennis
Old 06-22-2011, 02:46 PM
