Help me choose the next steps for my EFI Turbo Conversion
Hey Guys,
I did a pretty basic turbo conversion on my '87 Carrera a few years ago. I've since decided to move forward with an aftermarket EFI conversion. I've been collecting parts over the past few years, and I'm getting closer to starting the project work back up! Here's a quick recap on some of the internal mods that I've already completed: 1. ARP Rod Bolts 2. Supertec Head Studs 3. 930 Cylinders w/ 8.0:1 Pistons 4. Twin Plug Carrera Heads One of my constraints for the conversion is that I'd like to keep the body 100% stock. I'm keeping the Carrera tail and A/C. There's plenty of debate on the topic, but I've decided not to shoehorn an air-to-air I/C under the tail. For better or for worse, I'm going to follow the lead of fellow Pelican thechiller and use a water-to-air I/C. I'm probably going to install a large under-body radiator in conjunction with a wheel-well radiator w/ a high flow fan. It adds weight and complexity, which are acceptable to me. I have an Electromotive TEC3-R engine management system with a twin plug direct fire ignition that I picked up for a decent price. I don't have much in the way of the fuel system sourced yet. I've got new Bosch 55 lb injectors, and I'm planning to upgrade to a Bosch 044 fuel pump. I've got a set of AMS custom made headers w/ a T4 flange (thank you YermenCars!). I'm leaning toward a Precision SC6262 Turbo w/ T4 .68 A/R hot side. The guys at AMS have had success with the headers/turbo combo on turbo Carrera conversions, so I'm inclined that direction. My goal is to achieve 500 HP w/o exceeding 18 PSI. From what I've read in this forum, conservative opinion is that you should flame ring the heads after 1.2 BAR of boost, as they tend to lift off the cylinders. I'm not looking to set any records, so I'd prefer to play it on the safe side. I'd like to hear your input on my build plans. Am I missing anything that I should be considering? A few specific questions I'd like to run by you guys: 1. Will extrude honing my intake manifold be beneficial even if I don't port the heads given that I'll be dyno tuning the car? How about porting the intake manifold? Is that different than extrude honing? I'd prefer not to tear down the entire top end for further upgrades. 2. I've heard of several TurboKraft builds that are running 964/993 twin knock sensors. I believe the stock 993 bridge is used on one of the cylinder banks. Can this bridge be installed w/o tearing down the engine? Or does it require that the cylinders be machined? 3. What do you recommend in terms of the fuel system for my setup? Do I need to replace the stock fuel pressure regulator, fuel lines and fuel injector rails? 4. What else? I'm sure there's something I'm missing :) The car is in the shop right now getting a suspension refresh and upgrade. Stiffer torsion bars and Bilstein Sports. Big brakes coming in July. Thanks for help! |
Sounds like an interesting project with some twists.
Several years ago I polled the guys on this site who had high HP engines. I was looking at the impact of twin plugging. In the process I found their engines all fell in orderly fashion on an old Porsche engineering chart of boost vs. geometric compression ratio. All were running at roughly 12.5:1 effective C.R. on available pump gas. Represented was 7:1, another 7.5:1 and then 8:1C.R. At your chosen 8:1 compression ratio, 1.2P.R. is in no mans land but your goal of 500HP was demonstrated at .8 bar so the high boost shouldn't be needed. |
fire rings
Andy, what kinda power does the car make now and are you looking to get 500hp/500tq at the wheels?
I'm by far no expert on these 930s, but I have fire ringed heads going in my current build and just based on the stock fitment of 930 heads to cylinders I'd suggest doing it cuz stock is pretty loose and once they move there goes your seal...RC http://forums.pelicanparts.com/uploa...1308928330.jpg |
I don't think my HP goals warrant porting the intake and heads as the Carrera intake is 41.5 mm and the cylinder head inlet is 40 mm. Even ported 930 heads are smaller than this. Thoughts? A couple easier-to-complete upgrades would be a larger throttle body and extrude honed intake manifold. The Carrera throttle body is 63.5 mm in diameter, and it can be increased to 66.5 mm max. I've read about a handful of guys in this forum who have converted to Mustang throttle bodies that are around 75 mm in diameter. Are there any proven solutions out there for putting a larger aftermarket throttle body on a Carrera intake manifold? Any words of wisdom on the value of a larger TB or extrude honed manifold? |
Fitting a larger throttle body is not only unnecessary, it's usually brain damage. Skip it. Quote:
-044 pump adapters available from TurboKraft, Quote:
Thank you! |
I ran 42# injectors up to 8# boost with AFR's at 11.0 just hitting 85-90% duty cycle. You have to remember that the Carrera FPR runs the fuel pressure at less than the rated pressure for the injectors so your effective flow is less than 55#.
I have a single knock sensor mounted on the crankcase vent cover and seems to work OK. Given the choice, I would add the bridges and go with 2 sensors which is probably what I will do when I next tear down the engine. It is good to know you can machine the heads to fit the bridges which are inexpensive and not have to source custom cylinders. |
- the progressive nature to the throttle linkage was gone -- the installer just made it work, no care about the first ~50% of pedal movement opening the throttle only ~25% - manifold vacuum went away faster because every degree of throttle opening is allowing in more air than the system was tuned for. Maybe if the car had a programmable EFI system, it wouldn't do this, but the original Motronic didn't take it well. Quote:
I have seen some people use one sensor on the throttle console stud, maybe with the J&S knock unit. I can't speak for how effective this is. Quote:
Wish TurboKraft was in my area!! Very cool to read your Feedback on this Chris.
I recently got a quote for Motec, the pricing wasn't too bad but I was skeptical about their Porsche knowledge even though they claimed to have fitted them to dozens of 930s... The cold start, hot start mapping etc issues I hear of people suffering scares me, I don't want to turn my very reliable system into something high maintenance. It's why I was considering the MAP2ECU piggy back computer, I actually bought one. How feasible is a remote AEM installation provided by TurboKraft, impossible I imagine with tuning? |
Long distance on the AEM isn't scary. There's a huge online forum to help you with the common questions. And another gentleman in Melbourne with a 1994 Turbo 3.6 bought a system, installed & tuned it. PM me with your info and I'll pass it on to him. |
Thanks Chris, Motec don't actually install the systems themselves here, there's just tuning shops around that install them for you. Not sure if they even need to be authorised. Still Motec seems to be about double the price of other systems I've seen. So you can provide a system that is kinda plug and play? Thanks I'll PM you my details, hopefull he has time for a chat! |
| All times are GMT -8. The time now is 04:49 AM. |
