Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Crotchety Old Bastard
RarlyL8's Avatar
Building a Better Beer Can: Turbo Oil Sump Tank
You can't work with 930 exhaust systems without running into the aftermarket turbo oil sump tank. Most are just metal beer cans with a spigot and drain hose. Adequate yes, optimal no. As I ran across different turbos and turbo installation configurations I noted what would be needed to make them function better. Things such as:
- Vent. OEM's all have vents, great thing to have if some malfunction backs up the oil. If it can't leave the catch can it's going to blow through your turbo seals.
- Drain. It would be nice to be able to drain the tank without removing the return line.
- Aux Hose to Engine. Aftermarket turbos have different oiling needs than the OEM's so you may want the option of draining to the bottom of the engine.
So we combined all of these options, and more, into one fancy metal beer can with lots of spigots. You can attach the vent to the OEM hose, plug it off, vent to atmosphere, drain by unscrewing a plug or add an aux. hose to that same plug.
Now is where I need your help, pricing this little dude. I plan to offer these with my headers but will make extra for Pelican as a stand alone if there is interest and folks are willing to cover my costs plus a six pack.
Tank
Extra Fittings Capped
Barb Attach to OEM Vent Hose
Vent to Atmosphere and Aux Hose
Old 06-30-2011, 06:06 PM
Metal Guru
911nut's Avatar
Brian, looks nice and useful.
When I drain mine after an extended shutdown, it contains 7 oz. of oil (capacity is 8 oz.). I've often thought that switching to a ball bearing turbo would cut the required sump size by 50% or even more.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 06-30-2011, 06:52 PM
jsveb's Avatar
Pricing, I don't know, but it looks really nice.
About the six pack. If you ever head south. I have one waiting - Nice and cool.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 06-30-2011, 07:33 PM
Bri:
You always make all this neat s--- AFTER I have purchased something else.
Did you get your tin OK ?
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 06-30-2011, 07:39 PM
RarlyL8's Avatar
Ha ha, no it just takes a loooong time to bring these projects to fruition. We've got several things that are ready to hit, including the revised heat exchangers amd a little something for the 965 guys.
Paul, I've got to test out that ambient air vent using my car to see if the oil ever fills the can. In theory it should never get close unless there is a problem. What I was thinking when I added this breather gizmo was that it is very simple, eleminates the vent hose (which is a PITA to remove) and you can see real easy if the tank overflows. The system has to work better with pressure releived.
Jesper, I need a vacation real bad and we're thinking about heading south before the kids go back to school. May take you up on that beer!
Cole, yes I received the tin but haven't had time to unbox it yet. I'm building my next mule engine for a new twin turbo project. This one will blow your mind! Call me tomorrow when you get a chance I need to talk to you about the size of that flange, it looks too big to me.
Old 06-30-2011, 07:58 PM
Large Member
krasuskyp's Avatar
***^THIS^***
literally by a coupla weeks - d'oeth!
8-)
ah well...
Feedback? Looks TITS!
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 06-30-2011, 08:31 PM
Turbofrog
smurfbus's Avatar
Looks very functional.
Any drawback venting the breather to the oiltank breather? Not sure in what conditions the oil tank would let oil out of the breather?
What if the pressure valves fail (resulting too much pressure and oil flow) and your filter possibly spools the exess oil on the road? Mine does not have the oil tank breather line so I'm in the same boat so is it really critical? Just rambling...
Old 07-01-2011, 12:44 AM
RarlyL8's Avatar
What if the pressure valves fail (resulting too much pressure and oil flow) and your filter possibly spools the excess oil on the road?
That is exactly why I have it as an option. The OEM tank allows extra oil to puke back into the air breather assembly making a huge mess in your engine. Your first clue that this has happened is a huge smoke screen behind you and/or a locked up turbo. This tiny breather would allow the oil to flow out of the tank and onto the road, hopefully to be easily seen by you or others so you stop quickly.
If the tank is not vented pressure would back the oil up through the turbo seals costing you $$$.
It's an option. Use it as a breather, use the barb fitting and connect the OEM hose to air filter box, or cap that bung off.
Old 07-01-2011, 04:10 AM
After the next project
x98boardwell's Avatar
similar
I did the same thing on my old ride... the extra hole was just in case too much oil was getting in the can and the scavenge pump couldn't keep up.
Here is a shot. Looks nice Brian.
Regards,
Bryan
Previous cars:
1987 930, 1975 914 2.0, 1989 944 Turbo S, 1991 964 Targa, 2004 996TT Convertible, 550-6 Spyder with a 2.4 liter twin plug "S-spec'd motor"
Current cars: 2006 Cayenne TTS, 1991 964 Cabrio, 1997 993TT, 1984 Jeep Grand Wagoneer
Old 07-01-2011, 06:03 AM
MikeD930's Avatar
Brian,
That's a good idea adding fittings. One thing I would change is I would not use a vent fittings directly on the tank. This filtered fitting will be directly subjected to debris (would get dirty fast) and rain (would introduce water to oil system). Suggest to add a vent line and route it higher into the engine bay using a clear fuel filter and route it back down to the ground. That way if there's any problem with turbo oil pumped/drained from the sump tank it would overflow without pressurizing the turbo seals. This is what I did on my 930.
MikeD
'87 930
Old 07-01-2011, 06:05 AM
RarlyL8's Avatar
That's what I had in mind as well, thanks for posting a picture!
Mike, yes you can do that too with the barbed fitting I have on the picture above. Options ...
The little vent/filter is brass mesh. Very tight so no water should get it.
Old 07-01-2011, 06:07 AM
When testing the sintered brass vent to atmosphere on the sump tank for leaks after shutdown be sure to try that with the car parked uphill. Sometimes you have to park on an uphill slope in a driveway, parking lot, or streetside and it's possible that sump tank may fill up with more hot oil than on level ground and overflow out.
Also it's very likely and possible there are times at lower speeds the scavange pump will be sucking more volume than the amount of oil draining from the turbo will supply to it and there will be a good vacuum in the turbo sump tank from the scavange pumps suction.
My scavange pump has very high suction and vacuum even at idle speed - I know I've checked that with the hose in a cup of oil to check it and with my finger on the AN hose fitting at idle and the suction felt extreme.
In that situation if the sump tank has vacuum in it from the scavange pump the optional sintered brass air vent you have on there will be allowing outside unfiltered air to be sucked into the sump tank and engine oil.
In heavy rainy weather do to it's location inches from the road that can also suck dirty water into your oil supply.
Old 07-01-2011, 08:34 AM
RarlyL8's Avatar
Duly noted. The little brass dude probably does as good a filtering job as most K&N's, ha!
Old 07-01-2011, 09:42 AM
sudo apt-get purge 930
equality72521's Avatar
Did you come up with a price on this? I'll be needing one soon.
--clutch-monkey
Old 07-08-2011, 05:51 AM
RarlyL8's Avatar
I'll sell the first run at cost which is less than $200 and includes everything seen in the pictures (only 1 oil line though).
Old 07-08-2011, 06:00 AM
oilonly's Avatar
Brian count me in for one. with the one hose and all the fittings. As far as the beer I will credit you the amount as shipping it might be a hassel.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 07-08-2011, 02:11 PM
RarlyL8's Avatar
I had to order the 90* (how do you make the degree sign?) vent elbow as my local hose/fitting shop does not stock them. Hope to have all the accessories together in about a week.
Old 07-08-2011, 06:09 PM
Brian,
I think that's a reasonable price considering your time and sourcing all the little correct parts and sizing everything. We (Jpnovak and I) are getting close to getting our HFS turbo/efi/edis project into the car in the near future and Jamie noted the stock catch can wouldn't fit around the 993 HE's, M&K y pipe. If we can't simply swap one catch can (beer can) from the 78 930 to the 84 Narrow body turbo catch can I will be in the market for one and $200 is about what I would expect to pay before attempting myself. Do you have one ready to go?
John
John- I blame and thank the longhood boys of Austin
-84 911 Carrera w/ 930 t/p,efi'd,dizzy free,HFS turbo, 78 930 RoW no option sunroof coupe, 64 Corvette roadster, 71 911T, 73 911E, 67 Bronco survivor. 71 FJ40, 95 M3 (for sale)
"Illegitimi non carborundum"
Old 07-09-2011, 03:19 AM
Payment sent Brian.
--clutch-monkey
Old 07-09-2011, 03:28 AM
Alt 0176 should give you the degree symbol.
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!----
-1978 911 SC TURBO, Minerva Blue Targa 965 update.
-2008 550i M-Sport
Old 07-09-2011, 04:08 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
