sudo apt-get purge 930
equality72521's Avatar
Direct Fire Ignition
What is the most effective system for single plug? I've read about Electromotive, AEM, Ford EDIS6,... I am interested in simplicity and reliability. I am not doing full engine control, just ignition. Anyone have first hand experience?
--clutch-monkey
Old 07-03-2011, 12:40 PM
MSD DIS-4 Plus Distributorless 4 Channel - 62152
87 carmine red 930 | 57k | B6 modified IC | GHL headers | custom exhaust | VEMS EFI | carrera intake w/ flipped TB | LS2 coils | EBC | K27-7200 (soon to be replaced by GTX3071
Old 07-03-2011, 02:03 PM
Anything else?
--clutch-monkey
Old 07-03-2011, 07:11 PM
beancounter
jwasbury's Avatar
I'm happy with my electromotive XDI2. I am twin plug, but of course it can be configured for single plug. The XDI2 is laptop programmable, and will hook up with a standard GM MAP sensor for on boost timing control. Richard Clewett can sell you a set-up with the trigger wheel pulley and sensor mount and will provide after sales support. Easy peasy.
I haven't begun to experiment, but the XDI2 has programmable input and output channels. You can wire up a valet switch that triggers a lowered rpm limit. On one output channel, you can also set up a MAP vs. RPM duty cycle table. You could use an output channel to control a solenoid valve on the wur boost hose (similar to the rpm solenoid Brian Leask sells), or possibly even to control a frequency valve on the WUR control pressure circuit.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 07-03-2011, 08:42 PM
