89 930.
Benny771's Avatar
Question Little help with wur and idle ??
Hi:
Here are my symptoms:
when i installed a larger turbo k27 i noticed that the car popped on the down shift more than it use to.
Lately (this year) if the car was luke warm it had a problem starting, then chugged to life. Also when it is dead cold it has a hard time starting as well,this is a new symptom and seems to be getting worse(have to play with the gas peddle). It doesn't want to idle correctly until after a 5 min drive.
I have spent hours on here trying to see what it could be from others post.
I have recently changed the fuel filter and the accumulator (no change).
I do have a set of pressure gauges but i cant find a post on how to use them correctly, i have a manual but the photo's are washed out or unclear.
Anyone have a link for instructions?? I did see one before but i cant find it now.
I know your all going to want the numbers that the pressure gauge reads.
Old 07-05-2011, 04:06 PM
jsveb's Avatar
Hi
I have a thread that you can learn a lot from. Do's and don'ts with expert advice from this board.
There is also my instructions on how to test your CIS pressures. Including links to more prof. threads.
My 1978 wont start...help
Good luck.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 07-05-2011, 04:29 PM
PrimeMvr's Avatar
I had the same issue in my 87. The solution was to press in the larger of the two discs on the end of the AAR about 1/8". This opens up the slide for a bit more air when cold. You'll want to pull the hose and look inside first. If you don't see about a 1/4" gap when dead cold, this could be your issue. Also recheck the slider when it's hot to confirm that it closes all the way or you may have to push back on the smaller disc. Took me a couple of tries to find the sweet spot.
Old 07-05-2011, 05:11 PM
89 930.
Benny771's Avatar
Thank-you for your help. I will read up on the AAR.
Old 07-06-2011, 07:04 AM
