totle's Avatar
Now I have built a boost table for 1 bar in the ECU.
It will be controlled by a switch, so that I can select between 0.7 and 1 bar.
When I did some testing yesterday, it now seems like it is more precise and stable at 1 bar.
I did not see any increase in boost level as rpm increased
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 07-21-2011, 11:35 PM
Turbofrog
smurfbus's Avatar
FYI: My BB with a bit banged up (one of the PO to fit stock sump with BB) wg pipe does not flow enough to limit boost on higher rpms. I tried a 0.4bar spring and it still boosts over 1 bar at higher rpms. It's ok for now as the fueling is ok but I try to rework the pipe next winter.
Old 07-21-2011, 11:54 PM
R.I.P.
drmatera's Avatar
The devil is in the details.
Old 07-22-2011, 05:50 AM
