Billet throttle bodies
Has anyone here used a non-stock TB? I have read some pelicans have used the Wilson throttle bodies - these are cut from solid aluminum. What advantages do these billet TB have over the stock ones?
Basically, what are the main differences and how do these particular TB help or enhance performance over the stock units?
Thanks in advance,
Mark
Old 07-20-2011, 03:26 PM
Look at Accufab also.
The only reason to change the TB is to go larger than stock. Depending on the HP levels you want, there has been plenty of debate on the forums to whether it's worth it or not.
The billet is nice and machined smooth, but isn't going to amount to any big increase in flow over a cast TB.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 07-20-2011, 04:05 PM
E-man930's Avatar
drool...
Old 07-20-2011, 05:36 PM
As of now - TurboKraft has my manifold and it is getting "tweeked". I already had the ports polished and enlarged to 39mm. The manifold has been extruded honed.
Also, Chris has come up with a great way for me to incorporate WMI system. I will have 6 injectors placed on the back side of the manifold. One in each cylinder intake port (channel) in the manifold. This way the WMI system will not be seen - everything will be concealed. Bad news is - if I have to replace a injector nozzle, I will have to remove the manifold to get to it. Oh well, is always something when designing outside of the box.
Mark
Old 07-21-2011, 10:51 AM
Originally Posted by winrice View Post
the only reason to change the tb is to go larger than stock. Depending on the hp levels you want
+1
965 C2T / 1991 3.3 TURBO
Old 07-21-2011, 10:58 AM
totle's Avatar
I'm running 75mm Accufab throttle body on 3,2 intake manifold.
Engine is not stock though, but flows really well
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 07-21-2011, 12:10 PM
Chris from TurboKraft got back to me today. Bottom line: more bling than anything else. He informed me that they worked on a high modified turbo motor with the intake enlarged by 3mm. The owner had a billet TB installed. He said it looked great, but not any noticeable difference in performance. Except maybe in the owners own mind.
So - there we are. I really trust Chris. I have been doing business with him since he was with Powerhaus.
Mark
Old 07-21-2011, 05:27 PM
I had one on my car, don't know if it is still there, they are made in Ohio and used largely by the Mustang, Camaro crowd.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 07-21-2011, 05:45 PM
Schwarzeritter's Avatar
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
I can't speak about this product first hand. But it depends on the design and features. Not all are just bling and fashion. Diameter is a aspect not the whole equation as the butterfly and other aspects contribute. Think response refinement vs power.
Old 07-22-2011, 12:11 PM
copbait73's Avatar
Wide open throttle on a chassis dyno is just that. Unfortunately, WOT is a very small percentage of real world driving......but those HP figures really impress guys who like to compare the size of their dyno sheet to another guy's dyno sheet.
Old 07-22-2011, 12:47 PM
