R.I.P.
drmatera's Avatar
993 Turbo S wing on 930
Can anyone confirm that a 993 Turbo wing will fit on an '86 930. I could have sworn I've seen it done but just want to make sure before I buy.
Old 07-25-2011, 10:41 AM
Not without modification. It doesn't fit the opening so needs to be cut and mounting needs to be fabricated...at least mine didn't, maybe there is one out there that does
Old 07-25-2011, 04:01 PM
Large Member
krasuskyp's Avatar
say, didn't you just score / fit the DP replica looking wing?
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 07-25-2011, 04:23 PM
MikeD930's Avatar
Yeah, what Paul said. What's up with your fiberglass wing? Change of plan? Come on fess up!
MikeD
'87 930
Old 07-26-2011, 02:22 AM
E-man930's Avatar
You would be better off buying the 3.6 LTD wing from a place like Getty Design which would bolt right on... Regarding the 993TT wing, I have seen it done before, some fellow in Rennlist did it years ago. Lots of cutting, mocking up, using foam blocks to reshape it, and finally relaying the fiberglass. Then repeat if its not up to par.
Old 07-26-2011, 03:30 AM
R.I.P.
drmatera's Avatar
fitment has been less than good. Maybe good for a race car but the work we have into is far from what it needs to look right on the car.
Old 07-26-2011, 06:12 AM
R.I.P.
drmatera's Avatar
in the second pic you can see card board on the window. That side of the wing sticks up so high we have been sanding it down to try and get it close to looking right. The base of the wing just above the reflector fit horribly and has to be re-done to fit better.
Old 07-26-2011, 06:14 AM
MikeD930's Avatar
Oh wow...that's a bummer that it needs lots of work to make it fit correctly. Now I understand why you're looking at alternatives.
MikeD
'87 930
Old 07-26-2011, 06:22 AM
R.I.P.
drmatera's Avatar
this was parked next door today, I figured the real DP wing would fit better but it doesn't look any better
Old 07-26-2011, 02:52 PM
R.I.P.
drmatera's Avatar
Old 07-26-2011, 02:55 PM
E-man930's Avatar
You should keep your factory steel decklid and just swap out the actual spoiler - carbon if wou are worried about weight. That takes care of fitment and body / wear & tear issues on a street car.
Old 07-26-2011, 03:13 PM
Large Member
krasuskyp's Avatar
wow - huge bummer
fuchin lame that mfg's of aftermarket bits can get away w/ producing such shoddy wares - hear too many of these stories
sorry to hear that, that sucks - good luck whichever route you end up going
DAYUM on the DP... fekkin gnarly! Noice - tx fer sharin...
past:
Old 07-27-2011, 04:50 AM
E-man930's Avatar
tada!
PORSCHE 911 REAR SPOILER TAIL 993 LOOK FIT 1969-1994 - eBay (item 170302378787 end time Aug-31-11 18:05:50 PDT)
Old 08-30-2011, 05:57 PM
R.I.P.
drmatera's Avatar
Thanks, Now does anyone want an ill fitting DP style tail ??
Old 08-31-2011, 06:11 AM
MikeD930's Avatar
Hmm, I may consider it depending on how much you want for it. I'm afraid that shipping will cost $$. Shoot me a me PM.
MikeD
'87 930
Old 08-31-2011, 08:09 AM
E-man930's Avatar
Old 08-31-2011, 08:11 AM
R.I.P.
drmatera's Avatar
Thanks for the lead... That would be perfect if the under hood dimensions are equal to or greater than a stock turbo tail. It appears to slope down as it goes back, hopefully won't interfere with my intercooler
Old 08-31-2011, 11:05 AM
