E-man930's Avatar
Stuffing rubber in the back...
Hey everyone,
Can I get away with 335/30-18's in the rear on 18x12s without any fender mods?
Old 07-26-2011, 02:49 PM
E-man930's Avatar
specifically these ==> 335/30/18 BFG T/A KDW 2's
Old 07-26-2011, 04:14 PM
David's Avatar
I haven't tried putting 335's under my car but I have 315/35-17 BFG's and I can't see fitting anything wider under there. I had to grind off some of a suspension bolt on the left side to keep it from rubbing on the inside and the outside is about a 1/4" from the edge of the fender. That's with an 11.5 wheel.
2014 Cayman S
2011 Cayenne Turbo
Old 07-26-2011, 04:59 PM
Tinkering Pays!!
mooney265's Avatar
I have 335's under mine. Had to shave the inside lip of the fenders and 'tweek' my spacers a bit...
They leave about 1/4" from the spring plate bolts...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 07-26-2011, 05:02 PM
E-man930's Avatar
Holy crap...
OK, just trying to make this easy on myself.
Ordering a set of CCW Calssics in 18x9 FR and 18x12 rear with 255/35 and ??? rear.
Tire Rack has the KDW2's on sale / special and the don't have 1 315/30 size...
I sent John @ CCW an email - I'll post up what he says in the morning.
I definetly don't want to monkey around with anything - just bolt on and go.
I have 295s on 996TT wheels which are 11s and seems like to me I have a good 1.5" or so on the outside and another .75" on the inside of room before things get real close.
Old 07-26-2011, 05:18 PM
Tinkering Pays!!
mooney265's Avatar
345's
Oops... I have 345's... It's an older picture [have since changed the exhaust to gt3 center exhaust]...
Old 07-26-2011, 05:28 PM
David's Avatar
You could do a search of '335' on the turbo forum to get some input but it seems like a real hassle to fit that wide under there.
I bet a 315/30-18 tire would fit a 12" wheel just fine even though it's not rated for it if you decide to stay with 12" wheels.
2014 Cayman S
2011 Cayenne Turbo
Old 07-26-2011, 05:37 PM
Crotchety Old Bastard
RarlyL8's Avatar
345/35-15 yes, 335/30-18 no.
The reason is not width but height. The 345/35-15 is only 24.5" tall while the 335/30-18 is 26" tall. I've got a set of 315/35-17 TDK's on 11.5" Kodiaks and they barely fit due to the height issue. My bolts are shaved, fender lips cut off, and oil lines re-routed. The set of Michelin sport 335/30-18's I have sitting on the shelf have a full 14" sidewall width and must use a minimum of 12" wheel. Nomatter how I tried they just won't fit, unless you don't mind scraping at every bump.
I also have a set of 315/30-18's on 12x18 wheels which fit great and look great. My 345/35-15's have been retired due to NLA Yokohama tires. The Yokos were a full 3/4" wider than the Pirelli's that Mooney is running. It is good to note that each brand is a different actual size so some wiggle room exists.
Old 07-26-2011, 05:39 PM
E-man930's Avatar
Thanks everyone - I'll report back in the AM.
Old 07-26-2011, 05:52 PM
wow 345's that wide.
John- I blame and thank the longhood boys of Austin
84 911 Carrera w/ 930 t/p,efi'd,dizzy free,HFS turbo[/COLOR], 78 930 RoW no option sunroof coupe, 64 Corvette roadster, 71 911T, 73 911E, 67 Bronco survivor. 71 FJ40, 2001 Boxster
"Illegitimi non carborundum"
Old 07-26-2011, 05:55 PM
Tinkering Pays!!
mooney265's Avatar
Brian, you're right on the height issue... Taller would not be good...
Old 07-26-2011, 05:59 PM
E-man930's Avatar
What do you guys think of jamming a 265/35/18 in the front on 18s and then running 315/30/18 in the rear - Kumho Ecsta XS - apparently they don't offer a 255/35/18 which is what I was originally looking for and kicked off my whole 335/30/18 thought process. I'm trying to save $$$ on the tires and I want to stay with the same tire front and rear.
Old 07-26-2011, 06:39 PM
Large Member
krasuskyp's Avatar
I run the XS's (you're pronouncing it wrong btw, it's CUM-HO)... really like them. Rears are now slicks after 1 DE and maybe 7k-ish miles. Fronts wearing surprisingly well considering the cornering I do.
I won't opine about the size tho, other than I run 265/18s @ all 4 corners of Alumib!tch 8-)... SumiIII's tho...
Good luck - awesome score on the CCW's... I was about to heb!tch manslap you for running twists on such a fine build 8-)...
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 07-27-2011, 05:39 AM
RarlyL8's Avatar
When you get close to max dimensions fitment will depend on the tire brand.
By the numbers a 265/35-18 will be 0.4" wider and 0.3" taller than a 255/35-18 (which is the size I run with the 315/30-18 rears). This doesn't sound like much but 1/3" is huge when you are at the limit of fitment. Suspension settings become critical.
You really need to allow some wiggle room for potholes and lock-to-lock steering. The 255/30-18 315/30-18 combo I use are Pirelli P-Zero's; Pirelli's run small so they fit well with no issues of rubbing using street suspension settings. The 255/40-17 315/35-17 TDK's I run do not fit perfectly and rub on occasion. This is because the manufacturer (BFG) runs on the large side and these 315 tires are 3/4" wider than the 315 Pirelli's.
Old 07-27-2011, 05:41 AM
E-man930's Avatar
Well sadly never heard back from John @ CCW - assuming he is busy.
I"ll call him tomorrow morning and hear what he has to say.
Thanks everyone regarding the input on the tires - looks like the 335/30s are too large to fit back there - so now I'm hoping the Kumho's run a bit smaller only in their 265/35 fitment.
Old 07-27-2011, 02:20 PM
David's Avatar
You should be OK with 265's in the front. There are some guys running 275/40-17 in the front which are wider and taller. You may have some rubbing at full lock but you should only hit the locks in a parking lot.
When you're checking your offsets, check on both sides especially if your car is pre '86 since the fenders may be off a little side to side.
2014 Cayman S
2011 Cayenne Turbo
Old 07-27-2011, 03:25 PM
Large Member
krasuskyp's Avatar
...I just re-read the name of your post...
um, er, uhhhhhhhhhhhhhhhhhhhhhhhhhhhhh...
past:
Old 07-27-2011, 05:29 PM
LOL, Paulie!!!
Old 07-27-2011, 06:28 PM
RarlyL8's Avatar
Jeez Paul only you "wood" point that out!
Old 07-27-2011, 07:51 PM
E-man930's Avatar
Exactly... nice Paul...
What kind of sly remark are you going to make now that I may be trying to stuff rubber in the front and rear?
Old 07-28-2011, 05:11 AM
