boost pressure sensor thread pitch
I need to move the location of the boost pressure sensor on my intercooler as it interferes with my intake manifold. The local hardware store was useless in helping. The best I can figure, the thread appears to be the same as the drain plug, m18 x 1.5mm, can anyone confirm this? I need to plug the old hole and drill and tap another location.
87 carmine red 930 | 57k | B6 modified IC | GHL headers | custom exhaust | VEMS EFI | carrera intake w/ flipped TB | LS2 coils | EBC | K27-7200 (soon to be replaced by GTX3071 |
turns out it is the same as an O2 sensor, M18 x 1mm
Manassas, VA
1991 964 Polar Silver Metallic Turbo Coupe |
I ended up not needing the sending unit anyway. My VEMS ECU has an output to drive the boost gauge.
