? HELP- Oil in the WASTEGATE, Any Ideas on Origin or Causes ?
Where could it originate from and any speculation as to what may have caused it?
All your advice is greatly appreciated.
Old 08-02-2011, 05:44 AM
beancounter
jwasbury's Avatar
where exactly in the wastegate are you seeing oil? Exhaust outlet? Boost signal line or on the actuator diaphragm?
My first guess is that its the latter, which could be caused by leaking turbo seals allowing oil into the intake. Not particularly uncommon to find a little bit of oil inside the intercooler on these cars which will make its way into the boost signal hose routed to the wastegate. Another cause of oil in the intake is excessive blowby, compression gasses getting past the piston rings which can pressurize the crankcase, which will force oil out the crankcase breather which is eventually plumbed into the air intake (at least in stock configuration).
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 08-02-2011, 06:22 AM
Smart quod bastardus
fredmeister's Avatar
Jacob is 100% correct. You can determine better where the oil is coming from by seeing which side of the turbo compressor the oil is collecting on.
if its from the engine blowby it should puddle before the compressor on the inlet side. if its from blown compressor seals it will puddle more on the outlet of the turbo compressor.
You can try relocating the wastegate boost signal line so its not on the low point of the intercooler housing where the oil is going to collect. I am using an open fitting on my blow off valve housing which is on a vertical surface relative to the ground so little oil can collect there.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 08-02-2011, 08:29 AM
