Originally Posted by cellison View Post
Tony, the silver hot rod you gave me ride in a couple weeks ago with the muffler exit on the passanger side and the WG dump pipe on the left, is that one of brian's set up? it sure did sound good.
That was a 1977 Turbo Carrera and yes it is one of his. And I do agree it does sound good.
Anthony @ Voitureltd Bayside WI.
Old 08-05-2011, 05:54 PM
River Rat
Dave 86 930 Fl's Avatar
Originally Posted by jwasbury View Post
over here in JC Walt...I have RarlyL8 drivers side exit muffler and the SSI header set up he used to sell.
Jacob,
Any problems with the AFR sensor installed that close to the turbo? How long have you been running the sensor in that position?
Regards, Dave
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 08-06-2011, 02:58 AM
1986911's Avatar
Beautiful sound. RarlyL8 Hooligan:
‪RARLYL8 EXHAUST.WMV‬‏ - YouTube
I will try to post a better video
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 08-06-2011, 04:22 AM
beancounter
jwasbury's Avatar
Originally Posted by Dave 86 930 Fl View Post
Jacob,
Regards, Dave
I'm on my 2nd sensor. The first one lasted about 2 years.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 08-06-2011, 05:05 AM
Crotchety Old Bastard
RarlyL8's Avatar
Thanks guys, the goal remains to offer options on sound level and tailpipe configuration that are mix and match so you can create what you want in a system. ALL of the sound levels allow the same power production from your engine. The ID is 3" straight through all the way which is the same as a Zork tube.
The O2 bung is included for tuning purposes. For a permanent install a heat sink should be used.
Old 08-06-2011, 08:57 PM
Brian, on this set up for the driver's side exit, you have a pretty sharp 180 deg bend after the muffler. if this were a passanger side exit eliminating the bend would you get better flow, more power and a different sound?
Charles
79 930 #632
88 911 Cab
74 TR6
88 CRX Si
Old 08-07-2011, 05:02 AM
Tinkering Pays!!
mooney265's Avatar
I think PS exit would be better at getting the heat out from under the bumper... And, would look a lot cleaner from the back side
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 08-07-2011, 05:06 AM
Manassas, VA
lucittm's Avatar
Slightly off topic...
Brian could you fab a straight through "zork" to the existing tailpipe in the C2 Turbo? This would complement my test pipe and drop some weight, while leaving the symmetrical tailpipes. If you need a sample of the current Waste Gate Catalytic Converter Pipe, I can supply that.
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 08-07-2011, 05:40 AM
RarlyL8's Avatar
I used to make a passenger's side exit tailpipe with a matching driver's side exit WG pipe. This setup was discontinued due to all the fitment problems created by aftermarket headers and turbos combined with the limited adjustability of short tailpipes. It is always an option to run custom tailpipes off our muffler body and waste gate stubby flange.
There is no performance advantage with the PS tailpipes when compared to the 180 single or dual out systems. From what we have seen on the dyno the 3" ID is sufficient for up to 400WHP. The sound is of course louder due to reduced tial pipe length.
We just finished a system for the C2T which will use the same interchangeable muffler bodies, one of which is a bypass pipe. The stock tailpipes are retained. This system replaces the entire OEM system for a huge total weight loss. Paul B was a great help with this and has the prototype system on his beautiful charcoal colored 965. We'll offer this to Pelican as well after a few more positive feedbacks from systems in the field.
Old 08-07-2011, 07:12 AM
svb svb is offline
I have my 930 system for sale, and I'm in San Diego. See link. This setup sounded great and gives a wicked kick in the back on boost.
FS: B&B Porsche 930 full exhaust/headers
Boxster Spyder
Old 08-07-2011, 07:44 AM
oilonly's Avatar
That's why I bought the dual out setup from Brian. Right where that bend is their is a cutout for the passenger side pipe. Total free flow IMHO.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 08-07-2011, 11:54 AM
BlkBird's Avatar
My home grown solution, at least until 2014 when I no longer need to pass emissions testing. Ugly yes, but the catalytic converter allows me to pass annual testing without excessive time spent playing with the mixture.
Note the large sheet of copper on top of the pipe between the cat and the turbo. On top I have an O2 sensor for the Innovate A/F system.
Originally this was intended to be a temporary fix used just for emissions testing. But it flows up to 500 HP, works pretty well and is a PITA to take on and off. After 2014 one of Brian's systems will be installed.
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 08-09-2011, 11:30 AM
wjfk32's Avatar
I have to say that sounds really sweet.
Old 08-10-2011, 04:24 AM
