I did, but now that I think about it, might want to double check b/c I dont recall if I pulled the linkage to see if it would open more.
Thanks.
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!----
-1978 911 SC TURBO, Minerva Blue Targa 965 update.
-2008 550i M-Sport
Old 11-17-2011, 02:36 PM
Curious, does a 930 J-pipe bolt onto the 911SC heat exchangers OK?
I know it's not an optimal design, but it could be a cheap solution for an initial low boost system... and one can use any 930 exhaust with that solution too
Old 11-17-2011, 07:41 PM
Depending on the year of your friends car, you may have to source the early ones if you have an early SC. I believe the later years have thicker flanges so you will need longer exhaust studs.
Also the later ones I beleive were designed with a small lip which seats in the head but not sure if that would be an issue witan an early SC.
Not 100% as I did not go that route, but you're right would have been much cheaper than what I did.
Jeremy C.
-2008 550i M-Sport
Old 11-18-2011, 02:44 AM
Brando
quattrorunner's Avatar
[QUOTE=911TT33;6377888]Curious, does a 930 J-pipe bolt onto the 911SC heat exchangers OK?
Yes the J-pipe bolts to the sc heat exchangers. An easy part of the conversion. I believe the 930 and the sc use the same exchangers...at least the euro and later turbo version.
Turbo powa!
1977 911s. it's cool
Old 11-18-2011, 08:35 AM
