Mike80911's Avatar
Oil Lines
I seem to have a slight oil leak coming from the oil lines located inside the right rear quarter panel just above the rear tire on my 87 930. Does anyone know if there are o rings or some sort of seal at the connections? Or are they tapered and just possibly loose? I do not want to play with them until I am sure of what I am dealing with.
89 930 Cab Black
11 Cayenne
Old 11-15-2011, 04:59 AM
CaptainCalf's Avatar
Mike, it sounds like you're talkin about the lines that run to the thermo and then on to the front oil cooler in your front right fender. If so, there are no o-rings that I know of.
To track it down you could pull the rr wheel and run the motor to pressurize the lines to see exactly where the leak is originating.
I'd guess there are probably 2 sources in there:
1-a loose fitting
2-a ruptured rubber line
Good luck with your detective work
RC
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 11-15-2011, 06:13 AM
Mike,
there are hose - tube connections slightly backwards of the rear tire.
Maybe you should check them first.
Loose screw connections at the thermo are not very common I think.
Its a mess to unscrew the oil lines from the thermo. Last time I did this,
I needed to cut the hex screws with a dremel to get them of.
Be carefull with them, the threats on the thermo can be damaged easy.
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 11-16-2011, 11:24 PM
Look at "t-sat saver" thread for hint on he threads...
Old 11-17-2011, 06:42 PM
Mike80911's Avatar
Thanks for the input guys going to take a look this weekend and see what I can come up with.
89 930 Cab Black
11 Cayenne
Old 11-17-2011, 08:10 PM
