Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Champagne on Beer Budget
HelmetHead's Avatar
EFI distributor vs crank/cam sensors
I am working on my EFI again and stumbled across some older threads discussing the Accel 77911 distributor (dual sync)....anyone try this yet...pro's/con's?
ACCEL 77911 - ACCEL DFI Dual Sync Distributors - Overview - SummitRacing.com
Einar
87 911 Turbo
77 911 IROC project SOLD
http://www.flickr.com/photos/12148635@N02/
Old 08-12-2011, 11:26 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
proffighter's Avatar
We talk about you 87 turbo right? Then the Accel is useless, your dizzy turns counterclockwise... I think all 3.3 turbos do
So I dont think the gear will fit. Direction itself does not matter BTW
Roland
930 Turbo '81 Too many modifications to list
Old 08-12-2011, 03:00 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
CaptainCalf's Avatar
you could do what I'm doing and use a 964 3.6 flywheel conversion with the full sized 60-2 wheel configuration and use a sensor like the stock 964 Bosch sensor and sensor mount. Your 930 gear box bell housing will likely have to be notched for the sensor, but the 2 mounting holes should already be in your case...they were in my '87
Patrick Motorsports - PMP 24036DMEFW 3.6L 36L CONVERSION FLYWHEEL 9 BOLT 930 G50 240MM 964 993 DME MOTRONIC PORSCHE
1987 930 DTAFast EFI w/Electronic Dash, 17" Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo
1999 Harley Davidson Custom 1250 Bobber
2010 BMW 335iTT, 2012 BMW 128i, 2011 Jeep JK (Boosted 12psi)
Old 08-12-2011, 05:37 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
The distributor will work fine IF.... You are running an aftermarket ECU such as a Accel DFI or any programmable fuel/spark engine management system. You will need to use your gear off your stock distributor. The rotation is irrelevant with these units. They are extremely reliable. If you want it modified for twin plug let me know. G
Twin Garrett's, Big Valve, Xtreme Cylinder Heads, JB Racing cylinders and machine work, custom JE 8.1:1CR pistons, GT2 EVO cams, GT3 oil pump, modified 3.2L intake, 80mm TB, custom Intercooler, equal length headers, Accel DFI EFI
Old 08-14-2011, 08:18 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
HelmetHead's Avatar
Turns out my sensors were working fine..they were just in the wrong zipcode. I had a high syncRef value (93%) which required moving of the cam sensor to bring it down to ~65%...should eliminate some of my issues.
Einar
87 911 Turbo
Old 08-16-2011, 06:49 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
