Grappler
Thanks! That's the one issue I'm still working out. It's currently being drained to the spot next to the breather on top of the crankcase. There's a test fitting that was not in use, so I pulled it and got a metric to AN fitting. With the scavenge pump the system works, but not as well as I would like. The catch can fills up quickly so I need to leave the pump on for a few minutes after shutoff. Albert from GSF says that I'm returning the oil to the wrong spot because there is crankcase pressure there and at the same time, I'm trying to return there. He suggested that I run it directly to the oil tank. I've also seen a lot of people use the drain method to the crankcase via drain plug fitting, so I'm going to try pumping it back to the crankcase first. All I need is a $12.00 fitting and the return shot is less than a foot, so I'll try that first. My logic is that if some applications work with just a drain to the crankcase why wouldn't pumping it in be better? Plus the pump will act as a check valve so that oil wont drain back into the can and up to the turbo overnight. Again, that's what I think and I'll let you know if it works, but the top fitting doesn't seem to be the best place for my particular setup. If that doesn't work. I'll pull the oil tank and weld up an AN fitting. Mike, I'm waiting patiently for the D ZUG reflector. ![]()
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
Gravity draining to the oil drain port works very well, and the engine's oil pump has significant scavenge capacity which sucks the oil from the turbo and into the motor. Providing it's a decent downward slope, you won't have any issues with oil backing back up into the turbo
Grappler
That's what I'm thinking, but I'm actually using the scavenge pump as well to pump it back into the drain port. I don't know if there's any drawback to pumping it back in vs gravity but I'll let everyone know how it works.
7.0:1 > 11.3:1 > 7.0:1
Cool project. I enjoy seeing home brew and it's an interesting comparison you've described between the turbo and supercharger platforms, this is something I've been wondering about.
Early on you mention insufficient funds for standalone EFI, to which I'd like to contribute that if your AFRs are where you want them, and you have the timing curve you want then there won't be a whole heck of a lot to gain by going standalone. I take your car is a 911 platform? 915 or 930 box? Give us a side shot of your WHOLE car! |
JW Apostate
Oct 7th? Let's do that! KT
'74 914-6 2.6 SS #746 '01 Boxster |
Grappler
That was my thinking as well on the stand alone. This year alone I've done a complete IROC conversion, Lindsey wheels, top end rebuild, web cams and turbo conversion, so putting out another 2, 3, 4k? on a standalone wasnt something I wanted to do. I'll save that for when I join the big dogs here over 1 bar. Gearbox is a rebulit 915 with LSD so thats another reason for not going too crazy just yet. Overall with the car weighing in at around 2150 its pretty dam fast and it'll hold me over for a while. ![]() ![]()
WOW....love it.
Russ |
Now slip in some 930 barrels and up the boost to 1.2 bar, adjust your fuel & timing, and you're in 500+ HP territory
Chain fence eating turbo
I'm going Precision SC-61 eventually. How's the spool time?
Grappler
With this configuration it starts to spool at around 2800 rpm, spools up quick and goes straight to full boost. When it hits, it hits hard. ![]() 911TT33....my next thread will be "joining the big dog boost club". ![]()
Is this 4th or 1st gear you are referring to?
Grappler
Cruising in 3rd and 4th seems to spool between 2800 and 3000. I think 1st gear with full boost may be bye bye 915.
Love to hear when you make boost in yours. My G-50 Carrera doesn't make boost until 5500RPM in 1st.
Grappler
If I had a G50, I'd be more than happy to tell you... ![]()
Grappler
My winter project will probable be a gearbox and axel update. What do all you high horsepower junkies recommend? 930 4 speed or G 50? I'm sure the G50 is more popular but is it noticeably better than the 930 box? Are there other drawbacks to the 930 gearbox other than less top end on the Texas mile?
Can someone help me with the distinction between a Carrera G50 and the G50/50? Secondly, how do you find out which kind you have? I have a Frankenstein, so am just in the early thralls of discovery. Thanks. |
For identification the number will be stamped on the bottom pad. The G50/50 and G50/52 have a larger ring gear thus a larger diameter side cover.
I'm running a G50/01 with a reinforced side cover, great improvement over a 930 4speed. If you need top end look for a 50 or 52 turbo trans. Rodsrsr your car is looking great!
75 930, 76 930, 83 SC EFI turbo Last edited by lite75; 07-07-2012 at 03:37 PM.. |
Thread Tools | |
Rate This Thread | |
