Kartoffelkopf
Spenny_b's Avatar
Wastegate pipe - where does it go?
Hi folks,
A quick one for you pls - I removed the wastegate yesterday to get to the valve cover for a quick look/see...however, upon reinstallation of the WG when I went to bolt the banjo pipes back on, the one that fixes to the top of the WG cap/cover was extremely wobbly. All bolted back correctly, the orientation of the bent pipe follows the WG profile no prob, but when I look in the top of the engine bay, all I can see is that it has a bend that appears to go nowhere (vent to atmosphere?)
My thoughts were that it looks like it's come out of a fixing near the spark plug for #1 (another banjo bolt that looks to have a similar dia hole in the top), but the orientation of the pipe bend looks wrong.
There's no loose rubber hoses around either (I know the banjo pipe on the lower part of the WG comes through the tinware then joins a rubber hose, that's intact)
Any ideas pls?
(If it did come out of the holed banjo bolt, then a) it wasn't in there very securely, as I barely move the pipe, and b) it's going to be a right bugger to get back in place!)
Many thanks
Spencer.
Old 08-15-2011, 03:06 AM
jsveb's Avatar
I believe that it does vent to atm.
Old 08-15-2011, 03:11 AM
Kartoffelkopf
Spenny_b's Avatar
Thanks jsveb - my gut reaction is that it does - I can't see how I would have dislodged it with the work I did...unless it was poorly attached in the first place!
Old 08-15-2011, 03:27 AM
DSPTurtle's Avatar
The top pipe vents to atmosphere unless you have an adjustable boost knob. The bottom pipe connects via a rubber hose to your intercooler (assuming your IC is still stock and that no one moved the pickup point).
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 08-15-2011, 03:32 AM
Kartoffelkopf
Spenny_b's Avatar
Thanks DSP....have to confess, I did have a swear yesterday when I peered into the bay and found "open pipe" and "suspicious similarly sized empty hole", lol.
All stock for me apart from H&S system (with cat)...in fact, dyno'd the car last week and it's making 320.1 FWHP....let the (EFI) fun begin, heh-heh...
Cheers
S
Old 08-15-2011, 03:59 AM
