Boost Freak
Someone at work was raving about that Seafoam, but I haven't tried it. I've used that red stuff ... Stabil I think is what it's called.
I figure my car will set for 4-5 months over the winter.Any recommendations?
82 Porsche 930 Euro, black, 31K miles. Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
I thought Seafoam was a fuel system cleaner?
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
Boost Freak
Hmmm I don't know, I'll have to look it up and see!
Marine STA-BIL. The blue stuff....
'73 914 2.0, '74 911 Coupe, '74 911 Targa '78 924, '84 944, '86 944 Turbo, '84 911 Coupe '84 944 (current), '96 993 Coupe (current) '73 911T Coupe (current) '88 930S M505 (current) |
Seafoam is magic. It has done a great job as a stabilizer for my bikes in the very long winter. 1oz per gallon and you are gold.
1978 911 Turbo Cab Conversion w/1987 930 Engine |
Marvel Mystery Oil... 4oz to 10gallons...
Its easy on the wallet. ![]() Walt |
I used to use that but it is impossible to find anywhere in these parts anymore...
Ditto....1 oz/2.5 gallons fuel. Has worked fine for me.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Azzurro
I like the Seafoam product. I agree it's magic, I've used it in almost everything I drive.
anyone "fogging your cylinders" for the winter hibernation ? it's so humid here I wonder if there is any bad side effects by using a marine product for extra protection.
Metal Guru
The refineries, by law, have to supply gasoline with a higher Reid vapor pressure in the warm months, starting in the spring, to cut down on smog. The additives that do this are the ones that go bad over the winter.
So, if you have "summer blend" gas in your fuel tank then you will need to stabilize it to keep it from going sour. I don't put my car away until early November so I put "winter blend" in it. I've never added stabilizer and never had an issue in the spring with sour gas.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
I use Fitch fuel catalyst in my cars and my bike. The bike sits for about 5 months and I have never had a problem with gas. You simply put one in the tank and never have to add stabilizer again. Google it and read about it I have used them for about 5 years and the one in my bike still works.
89 930 Cab Black 11 Cayenne |
Driver
I used to use Stabil in my motorcycles. Others swear by Seafoam. Now I live in California.
![]() I did that for my bikes. But even with fairings it's usually pretty easy to pull the plugs and squirt in a few cc's of oil through a syringe and some tubing.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
I use Stabil Marine as we have 10% Ethanol gas here. Never tired Seafoam but I thought that was more of a cleaner vs stabilizer.
Charles 88 911 Cab 74 TR6 88 CRX Si 79 930 #632 (sold her and survived her) |
Forced Induction Junkie
+1 on StaBil.
They also make an excellent cylinder lubricant aerosol that you can into the spark plug sockets to coat cylinders over the winter months.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
