-   -   Ignition Timing, Help! (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/626832-ignition-timing-help.html)
jcc911 08-27-2011 04:33 AM
Ok so the title of my other post was a little confusing.
I need help figuring out where I should set my timing on my turbo conversion.
It is an SC engine with 930 CIS, 993 HEs, 7200 11.11, 965 IC, c/r 8.5:1, and think 91 octane.
I am using my SC distributor, and I want to make sure I do not have too much advance. So where should I set the timing? Should I run with the vac adv pot connected or disconnected?
Thanks. Jeremy
