930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
How much oil with front mount cooler?
The radiator style not the tube type. Tried Brad Penn and it did lower my oil temp by about 20 to 25 degrees(conventional to synthetic) I also replaced the front t-stat (inop) so I was wondering how much additional oil beyond the 12 quarts?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 08-28-2011, 05:34 PM
The oil in the tubes doesnt change with an oil change. You drain the case, the tank and refill is about 11 quarts.
Bruce
Old 08-28-2011, 06:45 PM
Wer bremst verliert
JohnJL's Avatar
Mine is 17 liters from a dry fill, with engine cooler plus setrab front cooler.
As stated above, you won't replace the oil forward of the thermostat unless you separately drain those lines. Even if it was hot enough to be open when you drain the oil ( hothothothot!) the thermostat will soon close before you complete the drain.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 08-29-2011, 03:58 AM
h20cooled7's Avatar
I flushed front cooler and lines while I had open.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 08-29-2011, 07:28 AM
steven c's Avatar
With a RUF cooler in addition to the stock one on my 965 and hot to open the stat it's a lot of oil...15 qts as I remember.
91 964 turbo
14 911S Aero Kit Cup
66 Corvette 427/425
69 Vette Race Car since 1971
Old 08-31-2011, 10:40 AM
h20cooled7's Avatar
I came in with 13.5 quarts but will run again and recheck.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 08-31-2011, 11:00 AM
