Tilikum Turbo's Avatar
Taller Final Gear or different gear pinion ratio for lowering RPM's on HWY.
I don't know a lot about transmissions.
Right now running a 915 tranny(no LSD) with a 3.3L stock motor, my car is turning roughly 3000 RPM's at an indicated 75MPH.
I do a lot of fwy driving, and would like to change either 5th gear from a 0.81, to maybe a .65-.70 ratio, or go the route of changing the final(is it drive pinion?).
Which might be the better route in terms of cost/simplicity to do this.
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 09-05-2011, 11:11 AM
IMR-Merlin's Avatar
When you change the final drive, you change all the gear ratios. So if you go with a longer final drive you are going to lose a little bit off the line, but all the gears will be longer. I am looking into this for my project, but it may not be right for you.
You can do some research here.
California Motorsports Porsche 915 transmission section
Old 09-05-2011, 11:35 AM
