Has anyone back-dated a 3.3 distributor before?
While I decide which EFI to try, I would like to backdate my 3.3 distributor to use it without an ECU. I have a '77 car so I don't plan to update the wiring to match the stock '87 engine.
Concerns: 1. The '87 3.3 distributor has reversed the direction of the drive gear that was in my '77 2.7, so I can't use either at this point. 2. I don't have, nor want an ECU. 3. I'm not ready for a crank trigger system until I choose an EFI setup. Any good suggestions? All I want to do is make the 3.3 disty accept my simple MSD setup, or find an easy replacement. Thanks! |
No 3.3L 930 engine has an ECU. All 930 distributors use mechanical/vac/boost timing curves.
So my 2.7 wiring harness will work with the 3.3?
I guess I assumed that it wouldn't work because I don't see any points inside. If so, thanks much! Now I just need to wire it right. I wonder where I can look for pics or diagrams for this swapover? |
| All times are GMT -8. The time now is 03:01 AM. |
