-   -   Fixing a 17 year old mistake, thanks OSI930 (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/628869-fixing-17-year-old-mistake-thanks-osi930.html)
IMR-Merlin 09-08-2011 02:33 PM
Back in 1994 someone thought they could just dial in some more power......
Although the car is not running, this has been driving me crazy.
https://fbcdn-sphotos-a.akamaihd.net...33771322_n.jpg
Thanks to OSI930 for offering me this key to solve my issue.
https://fbcdn-sphotos-a.akamaihd.net...38534126_n.jpg
Now to get the car done and create my own "bar" to achieve.
https://fbcdn-sphotos-a.akamaihd.net...56228188_n.jpg
PrimeMvr 09-08-2011 02:52 PM
I so feel your pain. Little things like that nag at me too. Late one night I ran a wire from a new O2 sensor to the AFR gauge under my dash. The next time I was under the car in daylight, I didn't like the path it took. I said "screw it, it's under the car" at the time, but after two weeks I just had to get under there and redo it.
Good luck with your project!
Anyone else have some fun "dang that bugs me" stories?
mark houghton 09-08-2011 05:27 PM
Yeah I do. At some point in my cars life, one of the PO's apparently replaced the sunroof seal. That's a good thing, but the bad thing is that the idiot installer slopped glue all over the place, on the paint (can be seen when the roof is open). My God, there just isn't any viable excuse for that. I'm sure something like acetone will take it off, but may take the paint with it. Just one of those things that bug me. Someday I'll experiment with a fix.
Roby466 09-08-2011 07:03 PM
I had to do that too with the boost gauge but when I suddently let go the throttle from full boost (0.9 bar), the needle jumps a bit to 1.2 bars so the red arrow is not all that good. Let me know if yours does the same.
Also, anybody knows where to get the key or what to use that works (I will try the head of a screw used in electronic components, it might work better than the long nose pliers I used before)
infraredcalvin 09-08-2011 07:50 PM
Hmm I always wondered why there was a big issue with the key, I can turn the silver hub with my finger on mine. No key needed... The annoying thing is that upon multiple boost runs the turning action of the needle will catch the telltale and continue to inch it past where the needle takes it. At first I thought I was over boosting, then while watching at full boost (not recommended) I realized it was catching. So I guess mine is broken in a few ways...
turbo owner 09-09-2011 06:25 AM
Try 3M general purpose adhesive cleaner, it works great on vinyl lettering adhesive and won't harm the paint.
JFairman 09-09-2011 07:09 AM
From your description it sounds like your boost gauge is hooked up to the intercooler wastegate line or somewhere before the throttle body. A quick compressor surge boost spike when you quickly close the throttle during boost like your seeing would be normal in that configuration because the blow off or compressor bypass recirculation valve needs a fraction of a second to respond and open to vent off the air pressure.
If your using the stock 930 recirculation valve it is big, heavy, and slower to respond than a small lightweight C2 type bypass valve from a 964 turbo.
You should be taking your mechanical boost gauge line from the brake booster vacuum line in the front trunk. That way your boost gauge reading is what the motor is actually getting from the intake manifold after the throttle body and not the slightly higher pressure from the intercooler before the throttle body.
Don't know where you'll find a keyring tool for adjusting the telltale needle other than http://www.nhspeedometer.com/.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
