Turbofrog
smurfbus's Avatar
I was a CIS noob a year ago. Had similar problems and bought the CIS pressure tester and installed WB AFR and followed the manual for checking different flows and pressures. In the end I pretty much understand the basics of the CIS system just by following the instructions I was given last year. I had wrong fuel head on my car and the symptom was too lean after 5000rpm.
Tell us your wur pressure readings: system (valve closed), cold (plug disconnected) and warm (plug connected).
79 930: HX40S#16, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, True split BB, 2*turbosmart38
Old 09-12-2011, 10:10 PM
Tinkering Pays!!
mooney265's Avatar
yes, I believe this is where you need to "re-start" the diagnosis...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 09-13-2011, 03:03 AM
