new slant nose owner here-overheating question..!
hi everyone...first of all, just got my slant nose this week, and have been very excited to drive it...
BUT...i have a question please...
i was driving for about 40 mins, (i live in manhattan) and most of it was miserable traffic, and the temp needle really got up there! is that normal? see pic..
thanks for the help!
phil
Old 09-15-2011, 05:50 AM
j930's Avatar
i live out here in Phoenix AZ, if i am not moving much I have had it come right up to the that bar you are at, but i am not the best comparison as I have not driven it at all this summer.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 09-15-2011, 06:00 AM
DSPTurtle's Avatar
Can you post a picture of the car? Is it an aftermarket kit or does it have the 930S cooler in the front? I have the 930S cooler and the only time it ever got that hot was sitting in traffic for 30 mins but cooled right down when we started moving again.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 09-15-2011, 06:25 AM
sure..here it is...not very good pic, i'm afraid...
Old 09-15-2011, 06:35 AM
Welcome to the forum!
That's too hot. We should NOT allow our cars to go over 250* - which is about where the needle is; however, taking it real easy - low rpms and short shifting - at those temps would minimize damage. Traffic is not our allied and in Manhatan that what you get. P-cars are not built for slow traffic. And yes, external coolers help - some.
Any more info requires full car pictures. It is a forum rule...
Old 09-15-2011, 06:43 AM
A front valance cooler would definitely help.
Old 09-15-2011, 06:45 AM
I would think there is an oil cooler in the right front fender with a fan on it. Check and see that the fan works.
If there is no oil cooler there and I don't mean a worthless trombone thing, install one with a fan and thermostat in the oil cooler to turn the fan on.
If there is a real oil cooler, fan, and thermostat something isn't working and the origonal thermostat screwed into the end tank of the cooler can be replaced with some BMW thermostat that will turn on the fan at a lower temperature.
Some people put in a switch or use the rear wiper switch if the wiper is removed to manually turn on the oil cooler fan when sitting in traffic.
Oil temp that high is not good.
Old 09-15-2011, 07:12 AM
thanks for all the advice guys...now another question please-anyone know of a good p-mechanic in manhattan, or near the city?
Old 09-15-2011, 09:15 AM
gumba's Avatar
No room for a front fender cooler in the slant noses. . Some years had them in right rear fender fed by the fender intake. If you don't have one there I would add one in the front spoiler.
Harold
'79 930/DP935
'68 VW Turbo Crewcab
Old 09-15-2011, 10:52 AM
I've gone native
Tt surgeon's Avatar
you have the twin of my car.
Old 09-15-2011, 12:55 PM
Tinkering Pays!!
mooney265's Avatar
Make sure you've got a good [clean] motor oil: I think this forum has settled on three: Mobil1 Synthetic EP or V-twin 20/50; Brad Penn Synthetic 20/50; or VR1 by Valvoline...
And, make sure your timing is not too retarded while at idle...
I added a front oil cooler with two electric fans [t-stat controlled]. One fan comes on at 95C and the 2nd at 100C. The second used to come occasionally, until I got rid of my 5* vacuum retard at idle... Even in 105*F temps down here in New Orleans, I don't see over 215F...
My cruise [highway] temps are usually about 175-80F...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 09-15-2011, 12:57 PM
kilodawg's Avatar
If it's an '87-'89 M505 the oil cooler is just in front of the passenger side rear wheel and can be seen thru the opening in the rear fender. To add a front oil cooler you will need to add the euro 930S valence. A much better look if you don't care about stock IMHO.
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 09-15-2011, 01:15 PM
Dr J's Avatar
I have a front spoiler like this one, with an oil cooler behind it. Sorry no pic of the cooler...
Spoilers 930 S FS1 & 911 S FS1
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI. Whipple Supercharged!
Old 09-15-2011, 01:30 PM
i saved a pic of a long time ago i am trying to find of that valance, the fog holes were glassed smooth and shut, just left the opening in the center for cooler, it looks amazing.
Old 09-15-2011, 02:49 PM
brooklyn ny 11234
930 slant nose's Avatar
brooklyn ok let me know for mechanic or call me 718 880 6065
thx mike
Old 09-15-2011, 03:19 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Hearsay until we see a picture...
Who Will Live... Will See
Old 09-15-2011, 04:11 PM
1986911's Avatar
Ok, they are Triplets
I had the same issue and the switch on top of the oil cooler went bad. It would not send the signal to turn on the fan when the oil got hot. What year is your car and is it a factory slant? I ask this because I can look at the wiring on mine and show you how to "jump" the switch so you know if its your fan went bad or your switch. But before this, I would start by changing the fuse and swaping the relay with a known good one.
Sweet car!
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 09-15-2011, 05:24 PM
Not triplets
Quadruplets!
1972 911S (2.7 RS Spec engine)
1973 911RS (2.8 RUF rebuild)
2014 GT3.1 Now available...
2018 GT3.2 Miami Blue, 6 spd...
Old 09-15-2011, 05:35 PM
1986911's Avatar
[QUOTE=69Sman;6256861]Quadruplets!
Sweet!! Can you post some more pictures of the wheels and provide specs. I love the speedline look.
Thanks!
Old 09-15-2011, 05:56 PM
kilodawg's Avatar
Hey would you guys please consider stopping by my Facebook "Flachbau" page and posting a pic or two of your car there? I'm trying to start a slant registry of sorts and just getting a handle on contacts and cars would be greatly appreciated.
Old 09-15-2011, 06:00 PM
