Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Distributor Question
Does anyone know off hand if there was a Euro version of the 86 930 distributor, or were they all the same? If not can a 78-79 Euro distributor be run in the 86 for different power delivery? I remember replacing the US version in my brothers 78 930 with a 78 Euro version, and it made quite a difference. Any input would be appreciated.
Old 09-17-2011, 07:48 AM
Crotchety Old Bastard
RarlyL8's Avatar
The smog controls on all 930's were very similar from '86-'89, including the distributor.
There is an advantage using the early Euro distributor as it has a more aggressive timing curve.
Old 09-17-2011, 10:20 AM
Smart quod bastardus
fredmeister's Avatar
Did the 78-79 US cars have the same as euro distributor or was it specific to the US?
I know the fuel heads and injectors were the same as Euro for these US cars but not sure on the dizzy?
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 09-19-2011, 07:31 AM
RarlyL8's Avatar
No the '78/9 USA cars has a smog distributor. The early Euro is easy to spot as it has only one pot with an idle vac retard nipple.
Old 09-19-2011, 09:39 AM
Registered Driver
Helmsy's Avatar
If you do a search on here there is a lot of info. on the different distributors and their functions and will answer all your questions.
Some cars have one vac/boost line and some have 2.
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 09-19-2011, 04:26 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
