Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
1980 911SC Shuts down
Hello, I have a 1980 911SC. When you try and start it, it will fire and run up to about 2500rpm then drops down to 900 and then dies out. It will do this about 4 times then nothing. If let sit 30 seconds it will do the same thing 2 times. IT has a new pump at the tank and a new filter. Seems to me that, and I don't know that it should, The supply pump at the tank does not run after ignition switch goes from start to run. If I can get it ti keep running around 3,500 it Will run but let off throttle band it dies out. Any help would be appreciated. Thanks. MrC
Old 09-20-2011, 05:35 PM
Banned
Hello, you posted in the wrong forum (this is the turbo/supercharger forum) - you would have much better luck posting in the 911 forum . . .
Old 09-20-2011, 05:52 PM
wrong forum
Thanks for the heads up. This is all new to me. MrC
Old 09-20-2011, 05:55 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
