Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Boost No Boost odd pressure?
Fairly new to turbos, still trying to learn the basics. I have an 89 all stock 930 that is experiencing intermittent boost issues. I first thought it was heat soak, but can now confirm that cannot be the issue.
Here are the symptoms. Jump in the car, warm it up, and boost comes on naturally up to 0.6 bar. Park the car, run an errand and no boost. Let it cool for an hour, and you get boost back up to 0.6 bar. But keep driving and it progressively leaves to the point where you have zero boost.
Now here is the part that seems odd. I installed a NHS gauge like this one: boost tap
It is tapped into the brake line. When you start the car the vacuum drops to -0.5. That is negative 0.5. I thought this was normal as the car would be pulling a vacuum.
Any thoughts on the issue? Could it be a faulty BOV, and if so do you just replace the part? Is there a way to test before you replace?
Old 09-24-2011, 02:57 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
