Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
DSPTurtle's Avatar
Oil Tank Plug (bottom)
Since I will not be using the standard oil separator I need to cap the fitting at the bottom of the oil tank. It appears to be a roughly M15 fitting. Anyone know where to buy one of these caps or how I can make one that will work? It's on the bottom of the oil tank so I am hesitant to do anything that might ever come out and dump 10qts of oil while motoring down the road listening to the radio.
Here is a pic of the fitting I need to replace with a cap...
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 09-27-2011, 07:59 PM
JB:
Just take the barbed insert and solder the round seat end hole shut, install it
back into the nut with the barbed end in the tank and put the nut back over it
and tighten it back down.
Mine has been running like that for about 20 years without leaking.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 09-27-2011, 09:14 PM
Driver
Noah930's Avatar
More importantly, why are you listening to the radio?
1987 Venetian Blue (really looks like grey) 930 Coupe
Old 09-27-2011, 10:14 PM
DSPTurtle's Avatar
I went to the hydraulics shop that made an oil hose for me. They just happened to have a plug in stock for a female threaded fitting. Plug is in, fitting is tightened, oil is staying in the tank. I love being able to do a job correctly.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 09-28-2011, 11:45 AM
BoxsterGT's Avatar
Porsche Crest
DSP-
Any chance you have the PN of this plug or know who made it? I need one also.
Len
Old 10-05-2011, 06:29 AM
DSPTurtle's Avatar
Hmm... we kinda just hunted through the boxes on the shelf till we found one that fit. It was so cheap they did not even charge me (or write up and invoice with the part number). Sorry. I have heard since then that a good old penny will also do the trick...
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 10-05-2011, 06:32 AM
mark houghton's Avatar
That's sacrilegious, a penny will not work. A Porsche commands something of higher monetary value than copper (or whatever metal they're made out of these days). Must be at least silver if not platinum to work on a Porsche.
And that coming from someone using copper plumbing elbows courtesy of Ace Hardware on my 930 (I painted them silver to look like platinum).
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 10-05-2011, 01:44 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
