GAJ GAJ is offline
964 Turbo Front rotors ignorance
Can anyone tell me if the 964 turbo 3.3 91-92 and the turbo 3.6 93 front rotors are interchangeable? can I fit the newer rotors to my 1992 3.3? both are 322x32 in size but can't find any reference on the hat sizes.
Thanks for the help.
1992 C2 Turbo in Rubystone Red
Old 10-05-2011, 10:27 AM
Metal Guru
911nut's Avatar
No they are not.
The '91-93 caliper and pad are somewhat smaller than the Turbo 3.6 set-up. All have the same size pistons but the 3.6 caliper and pad are 10 mm taller.
You can use the Turbo 3.6 rotor on the '91-93 but if you go to the 928 GTS caliper that got used on the 3.6 you'll have 10 mm of brake pad hanging off of the smaller rotor.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 10-05-2011, 01:02 PM
GAJ GAJ is offline
Thank you!!! you save me! almost buy the wrong ones.
Old 10-05-2011, 01:12 PM
TurboKraft's Avatar
Sorry, that's not completely correct.
The rotors are 100% interchangable. They have the same OD, thickness, and rotor hat offset. The only visual difference is the 3.6T rotors have a little more cooling fin in the middle, almost like a dividing fin in the same plane as the rotor surfaces.
You are correct about the pads, however. The C2T (S4) pad is the same length as the 3.6T/993T/GTS pads, only not as tall.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 10-05-2011, 09:31 PM
Metal Guru
911nut's Avatar
I disagree.
You have to lay the rotors side by side to see the difference. The 3.6 rotor braking surface is 10 mm deeper, toward the hat section. Other than that, yes they are the same diameter, thickness and offset.
The quick way to identify the 3.3 vs the 3.6 rotor is the hole pattern on the brake surface; the 3.3 rotor has an alternating 4 hole, 3 hole pattern while the 3.6 rotor has an alternating 5 hole, 4 hole pattern.
The 3.6 rotor can be used with the 3.3 caliper and pad but if someone wants to convert to the 3.6 caliper and pads, the 10 mm of pad depth toward the hat section will hang off the braking surface of the rotor which defeats the purpose of the bigger caliper.
But don't take my word for it, ask Bill Verburg.
Paul B.
'91 964 Turbo
Old 10-06-2011, 04:57 AM
Metal Guru
911nut's Avatar
Bill talks a little about this here: 964RS brakes
Paul B.
'91 964 Turbo
Old 10-06-2011, 05:08 AM
TurboKraft's Avatar
Now I see what you're talking about: the height of the friction surface. Hadn't noticed that before, but yes, the friction surface of the 1994 3.6T rotor is taller than on the 1991-92 C2T rotor.
Hadn't noticed the different C/D pattern, either, but it makes sense that as the friction surface is taller another row of holes was added, too.
Good to know -- thanks!
So the C2T can use the 3.6T rotors, but not the other way around as the lower section of the 3.6 pad would hang off the friction surface.
(Not that a 3.6T owner would want to -- the C2T rotors are more expensive.)
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 10-06-2011, 10:35 AM
fivehole...
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 10-06-2011, 10:36 AM
GAJ GAJ is offline
wow!! the only sure thing about this car is that I will never stop learning about her! thanks to all for the help!
Old 10-06-2011, 03:50 PM
