j930's Avatar
freeze 12
any of you guys used this stuff as a R12 replacement. I know a lot of you don't have A/C but its pretty tough in Phoenix with out it.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-07-2011, 07:14 AM
1991 c2 turbo black black
austin texas just has 90+ days over 100
envirosafe industrial - 2 cans + A/C vacuum + hard wired the condenser fan to be on high
my A/C rocked all summer
39 degrees if starting from shade or on Hwy
Hot car still takes a while to cool BUT the A/C blows cold right off
envirosafe is flammable But then ...so is Gas
Old 10-07-2011, 08:11 AM
89 930.
Benny771's Avatar
Using similar for years 10+. Works great. Installed it in over 50 cars. Never a problem.
I use redtek or duracool. Walmart sells it.
No problems.
Old 10-07-2011, 08:35 AM
you can buy real r12 on ebay after taking a 15min online certification class or informing the seller you are buying it for resale.
http://www.epatest.com/
87 carmine red 930 | 57k | B6 modified IC | GHL headers | custom exhaust | VEMS EFI | carrera intake w/ flipped TB | LS2 coils | EBC | K27-7200 (soon to be replaced by GTX3071
Old 10-07-2011, 08:45 AM
j930's Avatar
i got some freeze 12 today from a friend who has a repair shop. the supplier said they are no longer making it. i met a guy in line that goes to mexico and buys r12 buy the case for cheap but i guess its not legal in the us? i am going to charge the system tomorrow and i will post my results.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-07-2011, 08:05 PM
j930's Avatar
well i replaced all the lines this week and pumped it up with freeze 12. it works good. the temp got down to 56 sitting in my garage. outside temp was in the mid 80's. i don't have a compressor to vacuum out the system so i have just bled off maybe 1 can to try and get as much as air out as possible.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-08-2011, 08:04 PM
auto zone has A/C vacuum & manifold gauge set
leave credit card deposit and get it back when you return the set
Old 10-09-2011, 05:26 AM
j930's Avatar
i tried oreillys yesterday with no luck, if you guys think its of value to vacuum it down i can hit auto zone today.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-09-2011, 07:42 AM
89 930.
Benny771's Avatar
Well,
Most R12 sub do not need a Vacuum. But i still do it. Chech with the manufactures for the reason or a suggestion. If you get around 56 with no air going through the A/C system i would think you are good to go.
Old 10-09-2011, 08:21 AM
j930's Avatar
ran down to auto zone and picked up one, vacuuming as i type, i will post results to see if it gets colder
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-09-2011, 12:59 PM
j930's Avatar
so, we charged it up, high side pressure was way to high, almost 300. it now is only cooling down to 65 at idle. took it for a drive and as soon as we start going it stops cooling? it just blows warm
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-09-2011, 02:01 PM
j930's Avatar
so i need a experts help. We increased the RPM to 2000 and the high side drops so we put more freeze 12 in. right now we have about 18oz in there. i know that is a lot less then whats is to be in there but the at 2000 rpm the high side was up to 275. so the weird part is when i drive it after i am at about 3000rpm the air blows warm, if i bring the rpm back down it cools down again? what are missing here? i am thinking that maybe the higher pressure may be a result of the lines that i had custom made are smaller in diameter then the stock ones. not a huge difference but noticeably smaller
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-09-2011, 03:15 PM
j930's Avatar
oh and the outside temp is about 85, and i can get the thing down to 58 not moving.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-09-2011, 04:03 PM
Banned
This is probably too simple to be your problem (higher RPM blowing warm) but is it possible that the compressor belt is slipping at 3K and beyond?
Old 10-09-2011, 04:19 PM
j930's Avatar
thats a good thought, its not making any noises and its pretty tight, but i will check that. one thing is strange. we charged it the first time at idle, got the temp down to like 56. drove it and as soon as i hit anything above 2K it went hot. re read some posts and some POrsche instructions and it said to charge at 2K RPM. the higher the RPM the lower the pressure on the high side. we got another maybe 4 oz in it until the high side was around 275? then drove it and we thought we had it solved until i hit 3K rpm. then just blows hot? one other thing i had to do was pull out most all of that nasty insulation that is in the smugglers box around the valve. could that be causing me a issue? or maybe the valve that is in there is stuck? Very frustrating! again though we have maybe half of the recommended freon in it! so maybe we need more? but the pressure seems to high!
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-09-2011, 07:54 PM
T77911S's Avatar
18 0z's is not very much. you need to find out if the compressor is cutting off while driving or sitting still. if you have a low pressure switch, that will turn off the comp if the low side is too low. there should also be a temp sensor that has a bulb that goes into the evaporator, if that is not working properly, that may give you some problems, but you need to figure out if the comp is on or off and if off, why.
also when charging, it is good to idle up a bit, also turn the AC fan on hi and recirculate. you also need airflow over the condensors. when i charge my brothers, i put a box fan on the rear deck lid, you could also put one in front.
i never saw where you posted the low side, what is it?
911's will usually have higher high sides, especially sitting still.
all systems need to have a vacuum pulled before charging. for one thing, it will make the pressures higher, and its not just a matter of air, its moisture. when you pull a vacuum, the vacuum boils off moisture in the system, that is also why there is a dryer, to help get rid of moisture.
feeze12 is just a blend of several other refridgerants, surprisingly enough, 134a is one of them, i think the highest content, but dont hold me to it, its been a while since i looked all that up.
i had to look it up.
75% 134a and 25% 142b, about.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 10-11-2011, 08:48 AM
