Tinkering Pays!!
mooney265's Avatar
2 Very Small Oil Leaks
I keep the bottom of my engine spotless, so I can stay on top of any leak as soon as it starts.
Well, I've just had 2 separate leaks begin here recently.
1. Is at the union between the turbo scavenge pump and the cam housing
2. Is at the union between the engine oil cooler and the engine block
The leaks are both so minor, that hardly a drop of oil hits the floor, but I can definitely see the oil residue...
For the first leak, I see Part 930-105-197-05-M17 [Cam end plate gasket]. When I remove this pump, should I look at rebuilding it? I didn't see any posts regarding this...
For the second leak, I see Parts 999-704-173-50-M213 and [2] 999-704-172-50-M213 [Oil cooler seals]. Do these seals go bad? And, how hard is it to get the cooler out of there and replace them? Should I be looking at anything else regarding this?
Thanks, Shannon
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 10-17-2011, 06:07 PM
mark houghton's Avatar
I picked up a small dripper this summer as well. Pissed me off, but these cars don't go leak free forever (mine is most likely the lower left valve cover gasket...time to adjust the valves anyway).
I think a person can remove the oil cooler without too much difficulty, though I've never done it with the engine in the car. I replaced mine as a matter of course last time she was out'a there.
As far as the turbo oil pump....well, I have no idea so am all ears on this one!
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 10-17-2011, 06:20 PM
Tinkering Pays!!
mooney265's Avatar
Here's a pic of the oil pump leak. The banjo bolt is not leaking at all...
Old 10-17-2011, 06:23 PM
j930's Avatar
my 2 small leaks turned into a full blown rebuild. i love theses cars!had the engine and tranny dropped
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 10-17-2011, 07:01 PM
Shannon, I just fixed the same leak on my 86. No need to rebuild the pump. I just pulled out the old seal and replaced it with a new one. If I remember correctly I also replaced the scavenge pump shaft gasket. No more drips. Jeff
Old 10-17-2011, 07:28 PM
dhg1337's Avatar
I did both with engine in the car, the scavenger rubber o ring was bad, replaced it after i reinstalled the engine. i did not know it was leaking in the first place. I pulled the oil cooler also. All require a partial engine drop. alot to get to.
1977 930,no mods
Old 10-17-2011, 08:05 PM
DSPTurtle's Avatar
The joint where the oil droplet is sitting in your picture is actually dry. No oil runs throughout there. So you know it is not leaking from there. It's either to the right (in your picture) between the base of that aluminum and the cam housing or where the oil pump shaft comes through the housing. As far as rebuilding the pump, the only easily serviced part in that pump is the rubber o-ring as DHG said above. I would bet on the cam housing, triangular shaped gasket that goes behind that pump bracket. From the picture it seems like you already know that all you need to do is pull off the rear wheel and you have easy access. Pull the lines off first or you will fight with them for 15 minutes while jiggling the pump bracket around until you figure out that you have to put the housing back on to get the torque you need to get the lines off (please don't ask how I know that).
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 10-18-2011, 03:14 AM
Tinkering Pays!!
mooney265's Avatar
Thanks, will remove the lines first... Yes, i believe it's the triangular gasket that needs replacing...
Old 10-18-2011, 06:24 AM
Tinkering Pays!!
mooney265's Avatar
So, I really need to drop the engine [partially]? Was hoping no engine drop necessary...
Old 10-18-2011, 06:25 AM
Tinkering Pays!!
mooney265's Avatar
Thanks Jeff!
Old 10-18-2011, 06:26 AM
Tinkering Pays!!
mooney265's Avatar
You need to update that thread... Is it back on the road???
Old 10-18-2011, 06:35 AM
Tinkering Pays!!
mooney265's Avatar
What part # is the "shaft seal" for the scavenge pump?
Old 10-19-2011, 01:43 PM
can anyone put links or numbers up for the two seals needed to rebuild the pump...i cant seem to find them on here
Old 10-19-2011, 07:07 PM
Tinkering Pays!!
mooney265's Avatar
Is this the part[s] - - 33 and 34?
Old 10-21-2011, 08:42 AM
Manassas, VA
lucittm's Avatar
And the part listed as 32.
1991 964 Polar Silver Metallic Turbo Coupe
Old 10-21-2011, 06:10 PM
Tinkering Pays!!
mooney265's Avatar
Ok, thanks
Old 10-22-2011, 11:42 AM
After the next project
x98boardwell's Avatar
These may help.
Some pics for reference. There is a paper gasket that goes on the end of the cam before the smog pump drive goes on which has a tendency to leak as well. Figured it couldn't hurt to post some pics for you.
Best of luck,
Bryan
Previous cars:
1987 930, 1975 914 2.0, 1989 944 Turbo S, 1991 964 Targa, 2004 996TT Convertible, 550-6 Spyder with a 2.4 liter twin plug "S-spec'd motor"
Current cars: 2006 Cayenne TTS, 1991 964 Cabrio, 1997 993TT, 1984 Jeep Grand Wagoneer
Old 10-22-2011, 12:20 PM
930s don't leak, they mark...
Old 10-22-2011, 02:18 PM
