Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Originally Posted by lucittm View Post
Wouldn't extending the shift coupler out of its clamp a few mm's accomplish the same thing, moving the shift lever to the rear?
Mark
No.
The bottom half of the shift lever has to to point straight up without angling forward or backward when in nuetral or else it will cause problems getting the synchro hub slider teeth completely engaged into the gear selector teeth in second and fourth gear, depending on how far the shift lever is angled back from the correct position.
I don't expect you to believe that though.
Old 10-22-2011, 05:49 AM
Manassas, VA
lucittm's Avatar
JFairman,
Why would you say that you don't expect me to believe you? That statement is completely unrelated to the post and somewhat insulting.
I simply asked the question, and you answered it. That's all. No need to question my ability to visualize your explanation and judge it to be worthy of my consideration as to its veracity.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 10-22-2011, 08:31 AM
Originally Posted by vas930 View Post
The guys with the Wevo.
Are the shifts any faster?
It may be slightly faster due to shorter throws, but the syncros are what controls the actual shift speed, and they don't like to be rushed.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3 w/MS3X, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 10-22-2011, 04:57 PM
vas930's Avatar
Thanks WinRice.
Thats what I was thinking.
79 Silver 930 SOLD
Old 10-22-2011, 07:01 PM
Smart quod bastardus
fredmeister's Avatar
I installed a weltmeister short shift kit and also fabricated a short extension on a lathe that attaches to the end of the shift rod and extends the shifter by about 3 inches. I also bent it back towards the drivers side to shorten the reach in first and third gear.
Reattached the shift ball to the end of this extension piece and it works real nice.
Of course you still can't rush the shifts like a modern box, so instructors at track events are always commenting on how long it takes to shift and its like I am rowing a boat.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-24-2011, 01:52 PM
Boost Freak
Maxx1's Avatar
Angry
The 930 would be sooo cool with a sequential shifted 5 or 6 speed (much like on a motorcycle). ...or for Pete's sake, just a transmission you can slam gear to gear like the old Detroit muscle car Muncie M22 rock crushers! I'm afraid to shift mine too fast because of the poor feel of the gates ... I probably would miss a gear and blow something up.
82 Porsche 930 Euro, black, 31K miles.
Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Old 10-27-2011, 09:59 AM
The Wevo shifter helps in that respect, keeping it in the gates.
Even the old M22's would eventually need syncros, a little syncro teeth sharpening and sliders after too many slams, that's why I had 3 backups on the shelf in the old days.
1986 911 Turbo
Old 10-27-2011, 10:07 AM
David's Avatar
The WEVO's nice but don't expect too much of a change. I thought the coupler made more of difference. I bought the old style WEVO thinking I would modify the lever but haven't bothered. I did put a taller MOMO shift knob on it though to get it a little closer to the wheel.
2014 Cayman S
2011 Cayenne Turbo
Old 10-27-2011, 01:40 PM
How much improvement over a fresh rebuilt coupler with new plastic bushings is the WEVO coupler?
Just wanted to get an opinion before shelling out the cash for one of these since I have rebuilt my coupler already.
Old 10-28-2011, 09:05 AM
lin7310948's Avatar
i prefer the hargett in my 930. puts the shifter in such an excellent position for me.
71 911 all alum 434 sbc 585 chp 1959 austin healey bn-6 sbc zz4 motor 200r4 aod transmission......1959 Austin healey bn6 250 chev in line six cylinder, tremec 5 speed
Old 11-02-2011, 03:13 PM
shifter
What are the little red buttons?
Are both of your p cars chevy powered? Pics?
John- I blame and thank the longhood boys of Austin
-84 911 Carrera w/ 930 t/p,efi'd,dizzy free,HFS turbo, 78 930 RoW no option sunroof coupe, 64 Corvette roadster, 71 911T, 73 911E, 67 Bronco survivor. 71 FJ40, 95 M3 (for sale)
"Illegitimi non carborundum"
Old 11-02-2011, 03:27 PM
Blitzkrieg
jly535's Avatar
I've been dreaming of one of these. Do you just use a bock off plate in the original spot? Also how intrusive is the linkage? My kids still ride in back so...
77' 930
10' BMW F800GS
08' Tundra
Old 11-02-2011, 03:29 PM
lin7310948's Avatar
yes i covered the original opening with very thin aluminum plate. i would not think that the linkage would interfere with small passengers in the rear seat area. the conversion thread is on the technical forum...first purchase for another LS conversion....and yes both my porsches are v8 powered...the gulf blue coupe has a dart all aluminum 434 cubic inch small block chevy which makes almost 600 CHP. the 930 has a Mast MOtorsports 427 cubic inch ls7 drive by wire motor which dynoed at slightly over 700 CHP. the blue coupe weighs in at 2300 and the 930 slightly less than 2400.
Old 11-02-2011, 03:57 PM
IMR-Merlin's Avatar
Originally Posted by Midlife930 View Post
I have one from these guys. It is absolutely precise!
HPP Hargett Precision HPP
Dave
Been looking for something like this for my G50 conversion. thanks for the bookmark.
Old 11-02-2011, 04:16 PM
5.7 GT1's Avatar
Do you still have use of your E brake?
Old 11-02-2011, 07:46 PM
lin7310948's Avatar
no, i removed ot years ago. i believe that most do still have the emergency brake in place. not sure how they do it. perhaps shorten the handle and adjust the cables such that there is very little freeplay in them.
Old 11-03-2011, 01:24 AM
Originally Posted by johnbri View Post
I see you have two cars lost to fire.
What the hell
How did this happen ?
Our cleaning service cleaned out our fireplace the morning following a normal winter evening fire. They put the ashes in a plastic garbage bag(with trash) and put the plastic bag in a plastic garbage container in the garage. Ashes caught garbage on fire, caught plastic container on fire, spread to stuff in garage, spread to porsches, porsches exploded, and took our house down with them. Lost everything we owned and two family dogs. Really Sucked!
this is a terrible story. what a tremendous loss. i just saw this thread and must say this is really heartbreaking. here's to better days ahead.
very best,
pcb
Old 11-03-2011, 06:49 AM
